AlienGrey
Here is the Nailli card with update (bitmap version) if you want it gerber file let me know.
NickZ
   Hoppy:
   Ok, thanks. I'll updated as to new changes, such as the one below. As the effect, and other things are changing quickly now.
   Last night I played around with the idea that Geo, Tomtech, and apecore have been doing. And I placed another capacitor on top of my full bridge rectifier in parallel with the existing capacitor, (input from the 28t), which has raised the output significantly. Such as apecore had also just noticed. Which also seams to help control the rectifier diode heating issue that I've been having.
    Now the voltage at the bulb is at least 30% higher than yesterdays readings. And a brighter bulb, which now hurts the eyes to look at.
   Also now, three 100w bulbs increase in brightness when the Kacher is on. Previously only increase the brightness of a single 100w bulb. Tuning will continue, today.
apecore
Quote from: NickZ on September 06, 2016, 10:42:52 AM
   Hoppy:
   So, now voltage at the bulb is at least 30% higher than yesterdays readings. And also a brighter bulb, which now hurts the eyes to look at.
Ok ,.... party time i guess
Nice to hear you have eyes that hurt ;)
So i guess we are all at the next level now.
I hope Geo or Tomtech have some suggestions because it should be a matter of tuning now?
Next goal is to create enough power to accomplish powering the Kacher,...
The higher the output voltage the better the kacher perform....so wich may give a exciter effect to the whole system.
Suggestions are welcome
NickZ
    For me it's always party time.  It's happy hour, somewhere.
    The way that I have things connected now I'm able to power the Kacher, somehow,  even without tuning it on normally,  by using it's separate switch, from the power coming out of the full bridge).  Neon bulb indicator will light about 6 inches away from the antenna source.  Now, at times I'm starting to  hear some of those strange sounds coming from the yoke, and a little ringing also.
I try to avoid that though.  At times I turn off the PS, and the neon bulb that's next to the antenna, the neon (indicator) bulb stays on for a while, probably from the change in the caps.
apecore
Quote from: NickZ on September 06, 2016, 11:32:22 AM
Ok,... thats good.
But if you already didn't do it it is maybe time to put a fuse in your power supply to the push-pull mosfets.
Strange sounds and peaking Amps could kill one of your mosfets.
