0 Members and 349 Guests are viewing this topic.
stivep
short note  so you are not being drifted from main subject of  your discussion.
Filippo is just amazing me . A person with good conceptual skills
Wesley
NickZ
Quote from: conico on September 06, 2016, 01:38:35 PM
The  fuses are to slow, the mosfets burns quickly, you need an electronic protection, not fuses.
    Valid point, which I agree with. As it has worked well for me, at least so far.
    We'll see how well the el cheapo PS will work for the feed back loop.
   Stivep: Thanks for the update.
              Beta particle emitter???
AlienGrey
Quote from: Tomtech29 on September 06, 2016, 03:17:18 PM
Hi.
All is not as easy as it looks
I will try to bring you much closer as possible.
-we try to get three overlapping wave
- so LC circuit (gives us the conditions of the carrier wave)
- coil circuit grenade plus a capacitor and coil 28T
- reverses the direction of the wave (pay attention to the poles it's like the opposite of the magnetic circuit) getting knots called tail to form a standing wave!.
- and selecting only one of the first peak amplitude increasing and the rest of the noise suppression.
This is part of my theory Unfortunately, in the field of a standing wave in the guide there is little theory in this design:
https://www.youtube.com/watch?v=kOHzSYqjbtc
- I can not guarantee anything because I personally struggle with understanding all global information.
(it's like walking in the dark) It sounded dramatic but there is still someone who is trying to prove something or to stand up to the task :D
- I also think about the tricks of the stroke current to the top / some circumstances will be sought with the theme Kacher I'm sorry
I am opposed to encourage you to participate with this unfortunate high voltage in the form of a sinusoidal output
because of the growing need to provide the energy source in the form of a high current at the coil primary Tesli C.
impulse does not have such losses and you obtain a load of high instantaneous current (I do not know if this is true discharge the capacitor in the name may be a mistake Joules)
as a unit of measure?
- as to the placement of the foil within the grenade is such that the inductance drops still underway trial-something we are looking for opinions are divided
awaits us work experiments and so on...
Thanks and to hear again.
https://www.youtube.com/watch?v=pXXE4mwRiHU
next reasons to avoid HV.
like you is not surprising as it touches the finger a small spark!
https://www.youtube.com/watch?v=kr7fTDgsOrI
and let one of you touches it is only a joke (tap and believe) Hee.
it already you should give a thought
Ending the harassment monotonous pasting links.
Hi is your Katcher tuned to 1.677 whatever or is it just being blasted with that frequency so to speak or is it all over the place ?
Tomtech29
Quote from: AlienGrey on September 07, 2016, 11:33:50 AM
Kinda you have to rummage " Test with Led" you should guide the extent to which it is located,
Unfortunately output grenade see understate frequency 1.5Mhz due to the capacitance of the probe of the oscilloscope
Tesla coil operates at a frequency of 1.72 MHz. See the video "TTech"
- with regard to the flash bulb is surely and in a wider band.
Maybe I can repeat this effect :
https://www.youtube.com/watch?v=ymud5ES82Lc
I have not seen anyone show what happens when the driver Tesla is on and what it does?
https://www.youtube.com/watch?v=Z-UaulS9EUA
for this I am going to focus something perhaps that moves from place?
magpwr
Quote from: Tomtech29 on September 07, 2016, 01:56:44 PM
hi Tomtech29,
Please do not take it the wrong way what i am about to say.
Many of you can't even be bothered with the Physical aspect of the device as easy what you see from Akula.
For example just take a look at your outer coil without going into circuit(Which i never going to show the end result because of a single non technical idiot in this forum
which made me change my mind for good)do you think you have even come close to Akula.
Tomtech29-You used thick electrical cable for outer coil and see what you got not even close to Akula.I did used coaxial cable for trial some time ago and yet i did not achieve anything close as well.
Some idiots -no names mentioned even wind primary coil directly onto kacher.That itself reveal what kind of non technical idiot you are.I am no longer bothered to know why you are here in the first place.
That's all for now till demo.
youtuber:sanjev21
