0 Members and 327 Guests are viewing this topic.
T-1000
Hi all :)
Here is some feedback from akula about our current research stage which may lead to correct direction. It also includes questions for everyone to answer on own setup:
1) The series resonance coil - is it running on maximum resonance point with the given frequency already? If not, when you turn on Tesla coil it may just reach that point after. The Tesla have almost no influence to the induction heater setup when everything tuned as it should be.
2) Also does the resonance frequency match self resonant frequency or its harmonics on grenade bifilar coil? It have to work hand in hand for achieving maximum output of grenade.
3) For output gain from the environment towards OU: the current rise and fall have inertia time on grenade due electrostatic ion charges being pulled in. Do your Tesla coil have at least approximate frequency to that timing between rise and fall of those charges in each case? That timing have to match resonant frequencies on grenade coil which also is creating ion winds on the position of the Tesla top load(antenna). Note about tesla voltage - too much are sucking all electrostatic charges into Tesla coil and leave nothing extra for work to be done in grenade. Too low do not make pull of these charges at all.
4) What is the voltage on the antenna of the Tesla coil?
5) What is the frequency there?
The last three questions determine what grenade parameters range have to be on exact place for exact environment. For the 1st question when there is series resonance and the voltage is maximum on the capacitor. The main trick here is when Tesla starts pulling charges and disruptively shuts off before they are going through the Tesla coil to the ground. They are reaching grenade in "BEMF" stage and are being pulled in so the kickback cycle in grenade coil have power gain from the environment.
Hopefully that will help to advance... :)
Cheers!
John.K1
Hi guys.
For  T-1000's point 2)  You might find handy this calculator : http://gorchilin.com/calculator/reactor?lang=en
How to use it ( sorry- in Russian lng)   https://www.youtube.com/watch?v=pNFXlo5jv4g
AlienGrey
Quote from: T-1000 on September 08, 2016, 04:19:59 AM
Hi all :)
Cheers!
You have to admire Akula's comments, they saying a lot, without saying too much of use to the amateur radio novice  ;) you know you all should read up on Henry Moray to discover how his device worked or your missing the point and a whole lot more.
Anyway thanks for the T1000
regards AG
Hoppy
Quote from: AlienGrey on September 08, 2016, 07:49:54 AM
regards AG
C'mon Alien, spill the beans mate. Are you being serious that this contraption is based on Moray's patent for: An LC circuit resonator and a set of vacuum power tubes of diode type using uranium and radium power sources and doped germanium semiconductors on the cathodes, as descibed in Wikipedia?
T-1000
The level of language spoken is with assumption you already know how to synchronise two frequencies from different sources and have basic knowledge in circuit designing.
akula never go down to novice level explanations. Also in way he speaks the assumption is you already know what are you doing with radio waves and electronics.
