0 Members and 137 Guests are viewing this topic.
AlienGrey
DA1
Grumage
Dear magpwr.
It's great to read you're back.   :)
My research into OU has been considerably reduced since the installation of my 2 KW solar system in April. I am rapidly approaching the 1 MW generated mark!
However, I'm still looking for " Lunar " panels to help me through the nighttime.    :)
On a serious note, I personally have missed your input, looking forward to your next Akula replication.
Cheers Grum.
magpwr
Quote from: Grumage on September 09, 2016, 09:08:09 AM
Dear magpwr.
Cheers Grum.
hi Grumage,
If i recall correctly you are staying in UK.
I know that this is off topic.
Base on my knowledge it isn't that Sunny over there as compared to Asia or Australia.Although the global warming may have created longer Summer.
Yes i do have relative in UK.
Have you got a solar monitor device that reveal in any given day of the week that you even reach 1kw or at least 1.5kw at all for 2kw solar panel.
Base on my old research using a fork-lift/used fork-lift battery is a good option for the night provided there is excess power from solar to charge battery.
Replication or reverse engineering stage is over on my part as mentioned in my latest youtube video:sanjev21
uploaded sometime ago.Akula circuit is base on parametric oscillator using 4017 which is  divided/tied to the sub-harmonics of the L/C frequency.
That L/C frequency is also need to be tie to the kapanadze coil frequency.
That is the first step before even coming up with a circuit.That is already reveal in some other older Akula video in a not obvious way.signal generator/scope to coil to Earth. :D :D :D
Akula is right to say there are many layers  involved for this device base on old translation done by stivep or MenofFather.
Maybe think of it as loose coupling so that the kapanadze coil can resonate on it's own.
If anyone follow Ruslan using TIGHT L/C resonance there is no way for that coil to self resonate on it's own.Good Luck or No Luck with that Ruslan concept. :D :D :D
I'm using only high voltage Mica capacitors in parallel configuration to ensure frequency do not drift <5khz because Wima capacitors MKP 10 series does drift be it in pll or or other mode. :D
Problem with typical capacitors as temperature change it's capacitor value also varies.
I can't reveal too much since i need to show who is the smartest replicator.But i take no credit for Akula work.
I had this impression there are some smarter folks in here but no show or findings to date.
I am feeling depleted already after typing.I need energy for other activities.
