0 Members and 137 Guests are viewing this topic.
Grumage
Dear magpwr.
Many thanks for your reply.
I do live in the UK, North Wales to be exact. This hasn't been a good summer here but mid morning sun sees up to 1.75 KW ( real time ).
Keep up your good works.
Cheers Grum.
NickZ
  Guys:
  Ok, so here's a new video that I just upload this morning showing the "Geofusion effect".
  My last video was showing the effect only on a single bulb, this video is showing it with 3 bulbs.
  The 3 100w bulbs are connected only to the 3t coil, and there is no additional rectifier/capacitor on that part of the induction circuit. The output is taken off of the 3t coil/WIMA capacitor, and goes direct to the bulbs.
   The Kacher is running off of the 28t coil, and is rectified with additional capacitors, then going to the Kacher's input.
  The camera compensation kicks in after one second, so in order to actually see the brightness of the amplification effect, you must look at the bulbs only for one second from the time I turn on the Kacher, as after that time the camera dims the effect.
   My thanks for your collaboration, Geo. Together we making for a good team effort these days.
   https://www.youtube.com/watch?v=NKJpPyMBxwI
AlienGrey
Quote from: magpwr on September 09, 2016, 09:46:18 AM
hi Grumage,
I can't reveal too much since i need to show who is the smartest replicator.But i take no credit for Akula work.
I had this impression there are some smarter folks in here but no show or findings to date.
I am feeling depleted already after typing.I need energy for other activities.
one way to do it is to have a stable VFO and divide it down with selected logic so it's equally waited down to catcher frequency but it will need phase correction due to propagation delay but it would be a far more stable design if done properly. Any thoughts on the subject ?
A G
lacphong
Hi magpwr,
I'm guessing this is the circuit you're using.  Reverse engineering the PLL block diagram is not that difficult I think, the more difficult part is the parameters for the different coils.  If you don't mine I'm asking, are you winding your coil based on Akula's schematic, or are you winding it like Ruslan?
Thanks.
Quote from: magpwr on September 09, 2016, 03:01:43 AM
hi Jeg,
Thanks for understanding.But i was not stuck but i am just piss at all the collective minds put together at the present moment in forum.It seems nothing new since i became inactive contributor. ;)
But without the assistant of the forum members in the past to present i would not have figured out kapanadze winding itself.
But i would like to thanks MenfFather for without his old translation i would never have understand about manipulation of harmonics even today.
I am builing a second unit as well since science is about replication of experiment. :)
The completed circuit is only the size of my palm using smd components mix.
By putting this photo of the Russian transistor maybe some smart alex can figure out which circuit of Akula i am using.But i seriously doubt anyone is capable of reverse engineering certain aspect of the circuit which was merely shown as block diagram.
Do wait till for my demo.
magpwr
Quote from: lacphong on September 09, 2016, 04:54:01 PM
Hi magpwr,
Thanks.
hi lacphong,
I do hate repeating base on what i have mentioned in my old posting.
Only the key kapanadze winding is from Ruslan as mentioned before
.This is the only part he did right for the kapanadze coil only and not the additional coil to kapanadze winding.That fool only emphaize on resonance.Had everyone fooled as well including myself which kill precious time in months.
Why do you mention pll for Akula circuit if don't see a 4046 or vco inside a really simple electronic block diagram.
It's easy for me to know what level are you in at the moment. ;)
This is the last tips.Before i go radio silent till my Demo day.I think i have mentioned too much already.
At the moment i am beautifying my project to a respectable level.Only small constraint i have is space not time or money.
Too much time was spent to reverse engineer(Dark Art) this one experiment that i can't give it away in a flash just like that.
Beside the circuit is simple to understand if you have reached a certain level of expertise. :)
Side Note-I am also more curious about Akula like what is his background to derive all this solution.From a one man team.Think about it.
I would really appreciate input for anyone who is in close contact with him.
Since i have also detected really professional level hacking in my computer months back.To spoilt the fun all the key point is never stored anywhere.But i have already mentioned in forum.
I also call those guys idiots as well while hacking was in progress. 8)
To deter anymore fun i have mentioned i do have offline system. :D :D :D
To hoppy,
The NTC-1(Thermistors used as inrush current limiter.Value not mentioned) is a important component as well without it the circuit becomes very unstable which causes my battery operated circuit breaker to trip once kacher is activated.
Because i think i have given inccurate detail about this component months or one year back.So now i have even explain the cause and effect from this one component alone. :D
:D
Bulb always needs to be switched on last else all will fail as well for the parametric oscillator base circuit.
That's all folks.
There are other layers which i have not mentioned because you will find out about the " negative or positive biasing" as created via 4017(set at suitable divider setting). ;D
OK.No more input from here and see how all the collective minds perform against one. ;D
;D ;D
I think only Akula himself will already know what i am talking about. :D
:D :D
While i continue my stuff.
Youtube user:sanjev21
