0 Members and 308 Guests are viewing this topic.
Hoppy
Thanks for the tip on the NTC mags.
It appears from your report that you are on the right track and well ahead of the pack in progress. Its good to hear that you will be demonstrating your device to us on video. However, I trust that you have learnt from Akula and Ruslan's demonstrations, how not to video a self-runner.
AlienGrey
Quote from: Hoppy on September 10, 2016, 05:08:46 AM
please note an NTC negative temp coefficient, when hot it's resistance does not go down to zero ohms when it's hot, and Isn't the katcher the transmitter?
if your just using 12 volts your voltage will drop down considerably, for instance, 1R will limit the current drawn to 1 .2 amps in theory but in reality more like .9 amp, If your going to add this device you might want to seriously consider increasing your input voltage  to the circuit or looking at some sort of cold start circuit to charge the capacitors slowly on startup that involves some sort of overcurrent fault protection circuit.
AG
DA1
  Hi all
ผมส่งวงจรมาให้ดู
I look forward to circuit
NickZ
  "It's easy for me to know what level are you in at the moment."
   And equally easy for us to see that you are still needing a battery.
Hopefully you'll show us in your next video just how well your version self runs, without one.
   DA1: Please learn to resize your images to less than 1500 pixels wide,  as the one you just posted has messed up the thread.
Hoppy
Quote from: NickZ on September 10, 2016, 10:32:49 AM
Nick,
I think its safe to assume that it won't be a self runner and even if it is, neither he or anyone else is able to convince others using video demonstration alone.
Your latest demo is interesting as your bulbs appear to have stayed illuminated for longer than I expected after you disconnected the power supply. I assume you switched the power off from the white rocker switch? What voltage do you have across the three bulbs as measured with your scope?
