0 Members and 824 Guests are viewing this topic.
Enjoykin2017
Влияние ТТ на ток в контуре пуш-пул
TT influence on current in Push-Pull
https://www.youtube.com/watch?v=Dp5yGfWJzHI
Правильные эффекты в резонаторе
Correct effects in resonator (Grenade)
https://www.youtube.com/watch?v=oCAy88JFeA4
Резонатор (граната)
Resonator (Grenade)
https://www.youtube.com/watch?v=pNFXlo5jv4g
Контроллер Т.Т.
Controller TT
https://www.youtube.com/watch?v=Bhc1xFNgrVA
Контроллер БТГ
Controller BTG
https://www.youtube.com/watch?v=jeEaKI1TZ3s
Настройка датчиков тока
Tunning Current sensors
https://www.youtube.com/watch?v=NGG8Hk68Ikw
Управление затвором Схема включения драйвера
Gates control. Schematic driver stage
https://www.youtube.com/watch?v=jCest-tcObc
Пуш-пулл схема и настройка
Push-Pull schematic and tuning
https://www.youtube.com/watch?v=XDXTxPRPxSU
Повторение опыта Н.Тесла "U образная шина и лампа
repetition  Tesla experient on U shape bar and bulb
https://www.youtube.com/watch?v=2scp0SEotx4
ПЛОВ от STALKERA  :D
Pilau by STALKER  :D
https://www.youtube.com/watch?v=SE54G2kT7Z4
Сергей STALKER
https://www.youtube.com/channel/UCnKiEDi9e3SyctFmLtczLBg/videos
NickZ
quote from Hoppy:
Nick,
I think its safe to assume that it won't be a self runner and even if it is, neither he or anyone else is able to convince others using video demonstration alone.
Your latest demo is interesting as your bulbs appear to have stayed illuminated for longer than I expected after you disconnected the power supply. I assume you switched the power off from the white rocker switch? What voltage do you have across the three bulbs as measured with your scope?
                                end quote.
  Hoppy:  I'll let you know about the voltage, later. Yes, the white rocker switch does turn off the only power source to the system, which is coming from my PS.  I've now also placed another switch on the bulbs.
              Not trying to be like Twisted Sister:  Leader of the pack: https://www.youtube.com/watch?v=cO_brEreGLw
    For a little humor.
      You may know me well enough by now, that I'm not here to try to fool anyone, nor do I need to. Nor am I after fame nor glory. So, If and when I hit on IT, trust me to know that what you see on my videos, will be the real deal.
   And, if it takes me forever to get there... So what. I enjoy what I'm doing as it's my calling.
   Concerning the NTC1  (100 ohm perhaps), on Akula's schematic.  I've removed three different ones from Tv power supplies.  I'll see what they do, or don't do.  I'm not sure if I really need them or not,  as those controllable thermo resistors may be just another heater, restricting the power. And, I hate to waste any output power to heat, nor have I burnt out anything by not using them, either.
   Concerning the slow turn off of my bulbs, I attribute that to the draining of the caps with this last connection set up.
I'm not running a feed back path back to the induction circuits input, YET. Just a loop back to the Kacher from the 3t coil.
   ADMIN:  Please fix this thread, again.
                                                          Thanks.
NickZ
  Guys:
  After just watching one of Geo's videos, a funny thought came to me... He could probably put an big antenna on his device, and a speaker onto the coils, and tune in to Radio Russia. And transmit all the way to the moon on that thing.
Reminds me of the sound of my dad's short wave radios made when tuning into a station.
   I think that I heard him say.... Build it and   IT will come,  over the air,  all the way from his Island.
   This video: Replication of Urfa on Ruslan Akula Device Showing sync. Effect 1 - YouTube
    WARNING: Subliminal message!!!!   Watch at your own risk...
NickZ
  Hoppy:
  Voltage at my bulbs is between between 60 to 80 volts. When using 3 100w, 120v bulbs.
The higher voltage is not where the brightest lights are. Best output considering that connecting the negative clip of the scope onto the bulbs affects the reading, and acts to ground the HV part of the signal, my cleanest and best signal is at 60v. No tuning caps on, other than the parallel 0.47uf, and the series 0.1uf caps. And one cap on top of the DC cap that's on my inadequate rectifier.
   Rectifier output voltage 20v going to the Kacher's input.
   New MUR3060 rectifier diodes coming next week for making a new full bridge rectifier(s).
   My video quality will improve as well, to HD. I've also ordered a new cell phone with a good video camera. I'll have that next week as well. If all goes as expected.
   We have a nice $800 Canon camera, but at low light levels, video quality is not good.
    I sure wish that Itsu were back.  Things are starting to get fun...
AlienGrey
Quote from: NickZ on September 11, 2016, 12:47:42 AM
  Hoppy:
Struth Nick that camera is no good for ghost hunting then ;)  no green night vision images then, with some of the frequency bands some can cover it's a pity  we can't see some of the radiated energy. But hasn't Uncle Sam put an international evil world restriction on that sort of camera and owns the software 'you put on your I phone' !
A G
