0 Members and 824 Guests are viewing this topic.
Hoppy
Quote from: apecore on September 11, 2016, 01:10:47 PM
Nick, TomTech, Geo,
Guys,
After reviewed a vid from Tom this morning and connected it simular, i ve got alsos kacher effect.
Altough i have 230V bulbs i have also approx. 60V accross 3 bulbs.(Amp ratio would be different from the110V bulbs)
I connected them parrallel accross the series cap grenade to 28T.
Same as you the bulbs light when kacher in "ON".
But what i also see is that similar effect occurs even when inductor coil is not connected.
It seems that there is a lot going on in the yoke.
Perhaps makes it sence to see if your setups also acts in this way?...in other words to find out if the inductor does his job as we are expecting?
Greetings
I have for some time suspected that the Kacher is affecting the operation of the push-pull to increase output to the bulbs, through HV interference. This may be an important step forward, or a blind alley.
Tomtech29
Quote from: Hoppy on September 11, 2016, 02:04:34 PM
Hi.
I expected that somebody to praise as he also did it of this affair do not forget 1260Watt,in the middle brightness of 4 amps.
Give me the big guys
NickZ
  That's right Tomtech, but Ruslan did not start that way. And we are just starting to replicate some those same effects now.
   Nor do we have an electronics expert like Oleg, working full time, to create new circuits and different versions for Ruslan.
   Anyways, good to hear that you're still with us.
   Good luck with your current set up, also.
AlienGrey
Quote from: Tomtech29 on September 11, 2016, 02:30:31 PM
Hi.
Any chance you can scribble out the circuit you're trying to describe ? and perhaps you should see if you can display a scope screen shot or two as it all sounds RF induced that could mean the energy could just be rattling bulbs filament into some sort of brilliant action.
AG
Tomtech29
Quote from: AlienGrey on September 11, 2016, 02:44:38 PM
AG
Hi.
no longer want to go back to that used Pll
- but that without it you are able to set the two resonant points to try illuminate most of the number of bulbs?
- and what happens when you set kacher the current phase?
so I ask you because I have already experienced and do not know.
