0 Members and 258 Guests are viewing this topic.
Tomtech29
Quote from: John.K1 on September 15, 2016, 01:57:10 PM
I just wonder guys-  me and couple of  my "comrades in arms"  we discuss some interesting efekt , which might be "real" and related to this device OR it is just some sor of "ghost"
When we scan the grounded coil OR just connect oscilloscope directly with the SG)  and tune 25.xx KHz and go down to 200ms/div   you will notice something, what looks like standing wave or beat frequency" at very low frequency. Of course, you can than scale it up by multiples of frequency.  In different countries the same effect.
hello how are you John
I also went to the question of standing wave interesting that he, too, it shows:
https://www.youtube.com/watch?v=JHipZaGwd48
whether it looks like this wave?
- if you know the answer as he received in a given place heating coil?
the verification of the use of aluminum foil got smaller inductance but still do not know how this is reflected wave.
(the generator is connected to the reservoir LC  oscilloscope probe parallel).
John.K1
Hi Tomtech-   That's exactly the effect we see on our scopes.  Also as he said- tune it a lile litle bit bit up or down and the effect is gone.  My frequency alternates between 25.00 & 25.01 Khz  but the "beat" or "standing wave" is in Hz frequency for 25Khz feed. Feed it 8x up and the frequency will be in Schuman's range. Not sure if is it good for anything in this design.
regards,
Jan
Tomtech29
Quote from: John.K1 on September 15, 2016, 03:08:30 PM
regards,
Jan
so are you have a pretty shot without carrier , I connected to LC  3T but I also modulations like two waves see:
https://www.youtube.com/watch?v=feVm9qPJTMI
I checked it on the load 28T
https://www.youtube.com/watch?v=DXvvML9a06E
I do not know how it is up to the receiver?
- many times I've heard that in the construction of many roles that rectifier diodes to get half of the course
There may also be in series with the line ?
You can see a different scheme reminiscent of the kind of wave :
almost similar waveforms another structure
https://www.youtube.com/watch?v=YlMh3iuDXjc
These and other strange effects have something to discover.
AlienGrey
Quote from: NickZ on September 15, 2016, 12:01:51 PM
  apecore:
   If you look at the Akula schematic of his second self runner, he shows that the induction circuit resonant point(s) are 17KHz, 27KHz, and 37KHz, not MHz. While connected to the circuit, not it's free running frequency. Which also means that the Kacher should not be running at that same frequency. But, in the Mhz range instead.
Although I have not really seen the 1/4, 1/3, nor 1/2 wave rations, as the best frequency match, there may be something to that, as well.
  If you use a spectrum analyzer, you can see just where the best resonant peeks are found. Although they can and do change, and are not fixed points, at all. As changing the running frequency does induce different resonant points.
I hear what you are repeating here but the frequencies your referring to are different winds, I need to reiterate here they are the overtone multiplier frequencies, if you want to tune into Radio Moscow or Radio Luxembourg  you need to be on the frequency they are tuned to with the appropriate tuned coils and unless you have proper phase correction you get distortion, but we are turning to the 1/4 wave here because that's where the usable content is.
AG
Jeg
John did you measure the Hz frequency to see if it coincides with 50Hz or any harmonics of it?
