0 Members and 166 Guests are viewing this topic.
AlienGrey
Quote from: T-1000 on September 21, 2016, 04:24:39 AM
Hi Grum,
Sorry to hear that but there is always small Tesla coil and specific frequencies which may help.
Just ask ronotte (one of TPU guys :) ) in skype group chat how he healed his back.. ;)
Cheers!
I think its 7.83 hz  and 432 hz notice the numbers add up to 9 (the universe) frequency, also look up Bob Beck he was heavily into healing frequencies and Tesla coil, Tom Brown is another he is on FaceBook (Borderland  Technolagies) look them up.
apecore
Quote from: NickZ on September 21, 2016, 11:02:58 AM
   Grum:Let us know how it goes with this device, and IF it helps your back.
There's more than a few people with back problems, even after back surgery.
  apecore:  I finished the full bridge rectifier similar to yours, using the MUR1560 diodes, mounted on a heat sink, and I placed a single 150uf, 430v electrolytic capacitor on it also.
  The results are that the diodes don't heat up, like my previous rectifier diodes did, but the output is similar, but not better.
  Any suggestions on just what capacitor(s) to use on these rectifiers. I also made a capacitor bank that I can connect up, if it were needed.  And I also have several 1.2uf to 7uf caps of up to 450v that are NOT electrolytic which can be used, also.
Nick,
I have also several cap banks,..  so i can vary the amount of capacity.
I use non electrolyte 1000V types,.... you must be aware that without load the voltage can rise high.
This is also the case at the 28T connection ..... connected at the kacher its drops to 40-50V,..  but without it will go to 200V.
You don't want the ...."BOOM!!!
Further i think that a capacity of 10 - 30uF is enough
NickZ
  So, I've placed the cap on the output (DC side) of the rectifier, and I can power the Kacher through it, but, I need to know if the AC side of the full bridge also needs tuning caps on it, or not. All I can see on Ruslan's video is what looks like a black AC cap, possibly of 10uf or so. But, I don't know if he uses some other capacitors on the AC side of the rectifier as well. As there seams to be other capacitors in the white box.
  I've been getting a messy signal at the rectifier output, not clean at all. And my digital volt meter won't read it's voltage, either, like it can from the normal 24v power supply voltage.
  I still get an applification effect on the 3 100w bulbs, when the Kachar is also on.  And at times my yoke start to ring at certain frequencies, and to vibrate noticeably at other frequencies.
  Anyways, just reporting back what I'm seeing so far.
AlienGrey
Quote from: NickZ on September 21, 2016, 05:10:48 PM
YES YOU DO! ask Geo for an up to date circuit diagram Nick Geo has a .47 and 2 others in his diagram i think   the resonance in your case might be wildly different.
Enjoykin2017
