0 Members and 349 Guests are viewing this topic.
AlienGrey
Quote from: Enjoykin2017 on September 21, 2016, 11:35:47 PM
Free Energy ?  Why me ?  :D
http://www.youtube.com/watch?v=ZuJjy9wj9vU
Ingener99
Can you explain what's going on in English ? ;)
Top comments
stop Zhabei
abba zhaba1 year ago (edited)
So, if the wind heater so that's non-inductive bifilyarchikom, it will be extremely effective? It is that if there is no magnetic field, we have over the conductor ?? lose resistance ?? If the coil has no magnetic field, the electrons in the conductor fly sideways ?? less rub ?? If the effect is repeated dc ??? (Although non-inductive resistors wonderful heated) What is going on at all ??? Does anyone have guesses ??
Read more
Reply 1
View all 12 replies
stop Zhabei
abba zhaba10 months ago
"TAG influence of longitudinal forces in the CE stream" - sounds scary :) Can we find common ground?
Reply 1
filja prutkov
filja prutkov10 months ago (edited)
+ Abba zhaba If you are familiar with systems thinking, and if you are interested in TV transmission mechanism solutions of problems: "What Where When?" - Why not. Let us find a common language. - Of course if you already know what the free energy (COE) - by Maxwell and Tesla - is not perceptible ghost - PHANTOM, and these geniuses of mankind began to consider the reasons initiating secondary outcomes. Voooooot So, our problem is that the used secondary did not kill the root cause of the one that initiates these results. Then what will and a common language and understanding that in PHANTOM, but his elusiveness - there is something that gives in transformation. - This transformation of CE in its basis and contains the signs - which are based, we will be able to increase the efficiency of the systems. - What is actually required to prove. From SW.
Read more
Reply
Leonovmgn74
Leonovmgn744 months ago
Good day, dear colleagues. I released my article "Heavy Duty POLUDIPOLNOE microwave MAGNETIC FIELD compact form in ultrasmall volume of space." Link to the article in the electronic archive publisher's numbers here, on page 29 - http://research-journal.org/wp-content/uploads/2011/10/5-5-47.pdf
Read more
Reply
aRTUR Ko
aRTUR Ko5 months ago
my just better heat transfer due to the snug fit serdeshniku ​​and denser winding (double wire). In a transformer with a dense winding with a minimum of air pockets are much less likely to burn.
Reply
Leonovmgn74
Leonovmgn745 months ago
+aRTUR Ko, https://drive.google.com/open?id=0BySoaYxr8gZHN1J3M1RHU0o3dlk
Reply
Foma Sergeevich
Foma Sergeevich10 months ago
counter non-inductive winding, bifilyar - a kind of capacitor
Reply
View all 5 replies
Foma Sergeevich
+ Yury Leonov briefly read found inaccuracies on paper - in the current open-circuit can occur (cc HF) ferrites - conductive, it is easy to check (tester in resistance mode), and I think that the magnetic field itself and the electric itself, and the fact that they interact with each other, then that's another story
Read more
Reply
Yury Leonov
Yury Leonov10 months ago (edited)
+ Foma Sergeevich, but in this it is the problem of people - they do everything in the best case, only half, and sometimes even do not - Please read everything as it should be. I specify - The article open circuit used in the context of an open oscillatory circuit - hence - the current can not flow in the open circuit without the presence of an external electric field of tension - that is what was meant. I apologize for this inaccuracy (sometimes this is a false impression, when it seems that this time you understand elementary, others too should understand this). Generally speaking, Physics mistook the transfer point of the electric field of the real current - direct proof of this open oscillating circuit Heinrich Rudolf Hertz - can charge to move through a conductor with the near-light speed, and in the open oscillatory circuit judging by today's physics is exactly what happens. If you have the same intensity of an external electric field, of course, the conductor begins to compensate for the total electric field strength (ie, the electric field is made up of an external electric field and the internal electric field of the conductor atoms), which naturally will cause a redistribution of charges within the conductor - this redistribution already it is a stretch to call the current (Electrostatics of conductors - "electrodynamics of continuous media" LD Landau, EM Lifshitz). That is, I mean the situation where the conductor current density has a gradient along the length, as for example in a closed circuit with the potential difference (which is not the situation in electrostatics conductors with compensating charge redistribution in a conductor under the influence of the intensity of an external electric field). Accordingly, BB and RF - this is exactly the case when we present intensity of an external electric field, and the current is conditional compensatory redistribution of charges in the conductor. I believe that there are no absolute conductors and dielectrics - ferrites closer to the dielectrics, and not to the conductors. And so the glass can be electrically conductive - put it in the space of two incredibly strong opposition (compensated) giant magnetic fields, and glass (and indeed, any insulator) becomes a conductor, and vice versa - place any conductor just in the magnetic field of a giant size and this conductor will lose conductivity - Here we have agreed with you)) ... I think that the magnetic field and the electric field is the same - the proof of an elementary electromagnetic wave - Unfortunately, again, we do not agree with you))). .. I ask you, please, before the release of my last article about the inductance does not find, yet in my work malfunctioning (the more that you have not explicitly agree with my point of view - it makes no sense, probably repeating one another their position) and try to reflect on the work that is now napichkivayut our children in schools and universities (I put it on more than 13 years - maybe you'll be more agile ...), and insolvency which I personally admitted to our institute academic council - just do not want them to shame, but it would, I published what they have given me since met secretly behind my back ... Anyway, I understand your position - I respect her (everyone is entitled to his point of view), and, I think that you understand my point of view (so please respect and my point of view, too)), and I think that we have, unfortunately, probably nothing more to say to each other. Alas ...
Read more
Reply
filja prutkov
filja prutkov11 months ago (edited)
How can such a law be taken seriously, if you do not take into account the signs in the formula: The thermal conductivity, the contact zone between media and materials area with different heat conducting awns, as well as the general conditions in which is placed the system under study. - It is important to note: In the experiments Tesla - evident by experiments in which the process itself rather than Joule L. - cooled system, and the system does not have electromagnetic interactions. From SW.
Read more
Reply 1
View all 8 replies
Yury Leonov
Yury Leonov11 months ago (edited)
+ Filja prutkov Just here the topic is not on the Council of Europe, and especially scientific, physical - of the Council of Europe - in another place ...
Reply
filja prutkov
+ Yury Leonov All that is in their descriptions of nature, the universe, their laws, descriptions - is only subjectivity. And if - at least as it, the theme needs to be fairness (in truth or reality), then, whether we like it or do not want - in this case, what would be closer to reality - simply must not ignore Cause / investigative interconnection events that b - do not accidentally put the cart before the horse. Free energy is just the same, and is the reason / source / CE / that initiates all known forms of energy science and their interaction with each other. And if only manipulate secondary results that are known to science, then science boundaries extend - will not work. TE ..... and no more and no less. From SW.
Read more
Reply
Yury Leonov
Yury Leonov8 months ago
Good day)) Dear Colleagues! Today finished checking the difference of thermal work of AC and DC - is now quite clear that eddy currents have nothing and. One and the same conductor had the same heating at the same voltage and alternating current and a constant. Therefore, in the experiment of Figure 2 of the article "reduce heat loss in the current-carrying conductor UNDER THE INFLUENCE OF A SPECIAL SYSTEM OF MAGNETIC FIELDS", there was to be another physical phenomenon, apparently associated with the feature of the non-inductive coil in resonance as an open oscillating circuit, but it is only a guess, and accurately is only to say that in the conductor sections that in the experiment of Figure 2 of the article "reduce heat loss in the current-carrying conductor UNDER THE INFLUENCE OF a SPECIAL SYSTEM OF MAGNETIC FIELDS" were out of non-inductive windings are burned, current flows much exceeding the load current consumption (which, then, is 2200 [W] 220 [the V], and which, according to the laws of Physics, 10 [A] active current should consume value), and, according to the test of the same conductor of that same batch and the same coil to its temperature limit, showed that its insulating varnish starts to deteriorate already at more than 20 [a] of the active current, although continuous, though variable, is not important - it is in these areas proceeded which the additional current equal to load current consumption, but what kind of additional current - is yet to understand ... Tomorrow will be explored is the same winding, who participated in the experiment in Figure 2 of the article "reduce heat loss in the current-carrying conductor UNDER THE INFLUENCE oF a SPECIAL SYSTEM oF MAGNETIC FIELDS" and alternating current and direct current. On the results will be announced immediately ...
Read more
Reply
John Urbanowski
John Urbanowski8 months ago
good one !
Reply 1
Leonovmgn74
+John Urbanowski, https://drive.google.com/open?id=0BySoaYxr8gZHN1J3M1RHU0o3dlk
Reply
aaaflooddrying
aaaflooddrying1 year ago
Thank you for all your videos. Thank you for showing us. Very well done.  You are a class act. Delivered with style. Showing us, step by step.
Reply 1
Leonovmgn74
+aaaflooddrying, https://drive.google.com/open?id=0BySoaYxr8gZHN1J3M1RHU0o3dlk
Reply
viktorius64
viktorius641 year ago
The first - the current variable. Second - most likely sinusoidal. The third - the effect is observed only on the ring. The fourth winding depends on the method. On the ring - it means the ring in deeds. If you depend on the method of winding the interaction takes place directional magnetic pots. All this in the sum suggests that the basis of the effect is all the familiar electromagnetic induction. It neutralizes and inductive reactance and active (most likely not completely turns for very little, but this assumption) The resistance of the wire is still there, it is possible a slight increase due to the heating, but again and presumably mostly on straight sections of wire. The result is the EM induction emf, occurs at the site of the wound wire bifilyarom and directed by EDS with an external source. The resistance is still there but there was a force pushes electrons along a certain portion of the circuit and for the external source impedance of the site has declined. Heat is calculated by the formula shown in the video. Phase Resistance fell - fell heat. Why it fell when the active is still there - the second question. Perhaps the internal EMF bifilyara operates so that the electrons drags and pushing electrons external EMF lost electron polarization (changing the vector of the wave, and wave geometry) and therefore the electron moves not polarized, that is to say without a magnetic field around and nothing in the magnetic plane does not get up to conductor. It can heat associated with the MP but it is not. Maybe even a lot of things. But the most important formula - working. For an external source resistance area decreased - decreased heat generation at the site. Howe - I said it! On postoyanke is nothing of this - burn all the same.
Read more
Reply
View all 4 replies
Ingener99
Ingener991 year ago
+ Viktorius64 ring used for clarity, because with a small number of turns all clearly visible. Moreover, it confirms the purely magnetic mechanism of the effect (without the close location of the windings - heat sink or other container). The thermal conductivity of the ferrite is very small, and wire insulation.
Read more
Reply 1
Yury Leonov
Yury Leonov1 year ago (edited)
+ Viktorius64 totally agree with you. But read this one, and see firsthand, is quite another. As the old saying goes - better to see once than to hear a hundred times (well, read))) ... Unfortunately, it is our fault - we have chased forward, fascinated by further analysis and research that have completely forgotten and missed the main point - fixation on video, for reliability, all the work, and this applies not only to work on DC, but with regards to work with alternating current - if not Ingener99, people would not even have seen the effect of alternating current. We are, to our shame, even pictures do not make any. The only photograph that is now there (which is placed in the layout of the article), so this photo is complicated winding the conductor, which took place in the heat insulated duct inside this complex coil, and that its existence is made possible only thanks to the fact that the preserved and very complicated winding and guides that fit into heat insulated duct inside this complex obmotki.Tut, of course we should just apologize to all users for the fact that all the work behind the video, due to a lack of protocol video, looks rather pseudoscientific than than scientific, and can only hope to help these wonderful enthusiasts as Ingener99, because now almost completely stopped working, due to the impossibility of their further implementation, as well, and it is not possible to make any and any video recording ... I personally, I am now engaged exclusively main job (which would support his family), and continue to engage in a theoretical test of the influence of physical models of the system created by us for various existing physical and natural processes and teach English language (there is nothing to be engaged). Really, I'm sorry (!), But I'm physically and organizationally is unable, at present, provide nor any protocol video records and reading in Physics, unfortunately, is not an argument. I'm sorry, but if someone, or you do not spend your work (at least one) DC, the more of this or who can not do ...
Read more
Reply
Sir.
Sir.8 months ago
The current - is a live stream of the vortex conductor external environment and volatile vortex flows through the inner vortex conductor structure. As a result of the flow-torsion which is twisted inside the crystalline structure of the conductor (heating). In this case, the outer vortex flows offset counterclaims live stream (winding counter) in the ferrite material. In the experiment, part of the ferrite material to be heated and partially conductors. AC-DC power within a few hundred hertz, in this case, does not matter.
Read more
Reply
Valery Danilov
Valery Danilov 11 months ago
If possible, look at the coil thermal imager, will be clearer. Thank you.
Reply
View all 5 replies
Valery Danilov
Valery Danilov 10 months ago
+ Yury Leonov LLC is familiar to me)))
Reply
Yury Leonov
+ Valery Danilov, Thank you for your understanding)) ... Now, in parallel with the article about the physical nature of the inductance, cook a very interesting job, by all means, time and energy will be directed to these two high priority areas ...
Reply
Yury Leonov
Yury Leonov9 months ago (edited)
All welcome, dear friends)! Today published my last article "Physical model INDUCTANCE", yet only in electronic form - http://research-journal.org/physics-mathematics/fizicheskaya-model-induktivnosti/ . The electronic form of the article there is a misprint in the footnote "9," admitted my fault. Here are the correct footnote "9": "See Article" NATURE OF MAGNETIC FIELD "Scheme 2, where:. Enar corresponds to the SIS in this article, and Eprot therefore similarly Enaved, this article, and opposite Enar and SIS." Perhaps in print and PDF-version of the article will be able to fix it. I recall that the electronic version of the article will be posted on the website of the publishing house within a month before the release of the next issue of the publication. Then, the article can be found in the electronic archive on the publisher's website, in the corresponding month of publication. Good luck and success in your studies!)) Link to my PDF-version - http://yadi.sk/i/IW3BEN1tmF5DH
Read more
Reply
filja prutkov
1). Wind the wire to fill the rings - the effect will be - is palpable. 2). And if you do bifilyar connection is not all, as the end and beginning, and it will raise the effectiveness of the experience. From SW.
Reply 1
Yury Leonov
Yury Leonov7 months ago (edited)
Good day to all))! I apologize for the long absence. Winding from "reduce heat loss in the current-carrying conductor UNDER THE INFLUENCE OF A SPECIAL SYSTEM OF MAGNETIC FIELDS" was checked. The error was found in the description of the type of connection - it turned out that was there a serial connection non-inductive windings - this is a very important point (!) - As it turned out, this was the reason for failure of previous experiments, DC, when it was not possible to get reduce heat, but this is what I write here - http://drive.google.com/file/d/0BySoaYxr8gZHcnJySllOVVUxaGM/view?usp=sharing
... So that, in a pulsating direct current, which, in fact, be called and AC, all heating and reduction of running on alternating current, and is clearly evident. DC - then, yes, yet only indirect results, but I'll get to the thermocouple, and then we'll see already direct signs rightly or wrongly my physical models ... now back to the currents of Foucault - "but all the same it does move" - So as a simple inductive winding in a single connection (connection diagram 4), and in serial connection, the other as simple inductive windings (Wiring diagram 1), warmed up more than the same simple inductive winding in series connection with a non-inductive winding (connection diagram 3), consideration of the reduction of heat in terms of the influence of eddy currents, forcing a new look at the physical model of the eddy currents, as in Figure 3, the connection between the simple inductive and non-inductive coil winding magnetic coupling is not present, but there is an electrostatic bond ... Just does not leave himself without attention and the fact that the resistance in the circuit of connection of 3 course is the same as in the Scheme of connection 1 ... in the meantime, Foucault currents, as part of my physical models described in the article "the Nature of Magnetic Field", you can imagine as the displacement of electrons in atoms unmovable shells relative to their nuclei changing potential in the AC circuit (See. Chart 13 "Painting the AC component of the magnetic field and the magnetic field source is a permanent component"), where the unmovable-shell electrons in the DC circuit has a DC offset, relative to their nuclei, and in the AC circuit, respectively, unmovable-shell electrons have a variable displacement relative to their nuclei, but they do not leave their atoms ...
Read more
Reply
Life is illusion
Life is illusion8 months ago
Everytime I begin to think I know something about electricity, I find something, just like this one that drops my jaw and leaves me watching the video with an open mouth! Hufffff, Thanks my friend for sharing, this was amazing :)
Reply
View all 3 replies
Life is illusion
Life is illusion5 months ago
+Leonovmgn74  Unfortunately I don't speak Russian, but from the videos and drawing I guess this system is not working? Or did I understand everything wrong? Thank you for posting the file for me.
Reply
Leonovmgn74
+Life is illusion, please)). Unfortunately, there is no article in English. In English you would understand everything...
Reply 1
filja prutkov
... Obviously! Many people know! Peltier element of the temperature difference - provide electrical power. Then, since there is a FACT - where hot and cold - are winding - We have an opportunity - the coil attached on both sides of a Peltier element - then stuck through the heat coil conductor allow to have a heat output of electricity power converter. What will add efficiency of the heat pump. Increasing the efficiency of this method - the system will become self-sufficient and autonomous. THOSE. - BTG! But I have no way to check it. The lucky ones also have a dozen panels Peltier - can easily verify this fact. From SW. PS1 - For the start of the experiment, it is possible to measure the difference in current consumption without the element, and then to consistently included in the supply chain of a Peltier element .... PS2. Would be lovely, if developers Peltier - would have considered this message - would have implemented its technology directly to the Peltier element structure so that used to raise the temperature conversion efficiency of commercially produced items. And the best of circumstances - would have given me a generator Peltier number 10 - 50 - pieces for experiments. In experiments where - what would get the Finnish sauna - heated one candle.
Read more
Reply
Alex V
Alex V1 year ago
It may also be options: 1. In the site right before the fault occurs, and no current flows through bifilyaru. 2. Winding bifilyara fit snugly to the core - and better heat dissipation as a result of a wire.
Reply
stop Zhabei
+ Alex V version is an interesting way ... certainly would not want to be that it was a trick ... but it's closer to reality ... Again it is necessary to try to =)
Reply 1
Yury Leonov
Spend Restatement experiment in Figure 2 Articles "reduce heat loss in the current-carrying conductor UNDER THE INFLUENCE OF A SPECIAL SYSTEM OF MAGNETIC FIELDS" DC, I, nevertheless, tend to agree with the version of the Foucault currents - http://yadi.sk/i/ M6mztWI2nBKyQ
Reply
iev911
iev911 1 year ago
For persuasiveness must be a third the same ring with a double winding, but where the currents have flowed co-current!
Reply 1
Yury Leonov
+ Iev911 answer from the authors - yes, that's right - we held and the study. We used four coils wound Ayrton-Perry, in order to eliminate the axial magnetic flux front ...
Reply 1
Yury Leonov
Hello dear users! Finished 2 article (from my series of three articles on "Electrodynamics and Magnetism") "THE NATURE OF MAGNETIC FIELD." Link - http://yadi.sk/i/QD7Ln7QFk3Mkq
Sincerely, Leonov V.
Read more
Reply
Jeg
It looks to me like thermal losses take place only when there is cemf across the transferring line. No cemf means no opposition to any change of current. If opposition to change translates to thermal losses then something really interesting is going on here. Just imagine how efficiency can be increased to our today systems.  :o
lacphong
Anyone who understand Russian please translate these PDF.
Thanks much in advance.
Enjoykin2017
Quote from: AlienGrey on September 22, 2016, 10:25:04 AM
A.G. Yes in a few words !! It is so simple  - governement trolls do their payed duty - trolling Mr.Yuriy V.Leonov successful work, his results and his research.!!
ps: Free Energy devices and discoveries were suppressed all over the world. From America, Germany at west to Russia at east. Even in China and Japana. This is a real situdation at the current moment of realm.
ps: About his explanation Nature of Magnetic Field i dont agree with him.!!
Nor one intrinsic electrical displacement or intrinsic charge displacement can produce Magnetic-Field !! Why ?? Because Magnetic-Field is another STATE OF MATTER. Kind of DIPOLE MATTER. It means - has MASS in steady state. He was deluded by fact that electron flow through conductor produce magnetic field. Why is so ?? He didnt took in accound the giant inertia forces which can easy crush electron on intrinsic matter particles. And that matter is Electrical in nature (photons) and Magnetic-matter (Dipole matter) which is in center core of electron shell. So you cant destroy the matter nor electric nor magnetic - because it is undestroyable. And only the matter is carrier of forces !! We know density of electron is 15 000 ton/cm3 and only giant inertial forces which were produced then we accelerate or decelerate electron (by accelerating volatge) have enough power to overpower strong Coloumb forces which act in electron shell. Density of magnetic-matter in electron core is 4 order of magnitude higher than density of electron. Why nature made it so dense ?? There must be a reason. So - nor one force except giant inertia can crash electron and release electron mass out. This released electron mass is a source of fields. Electrical mass (photons in outer electron shell) make Electric field while Magnetic mass make Magnetic-Field. From this explanation proceed that both sort of fields have PARTICLE NATURE - and not imaginary WAVE nature. But in any case we can modulate both kind of released electron matter (making electric waves, magnetic-waves or short-living electro-magnetic waves) , simple vary density and kinetic energy of these fields.
I hope finaly will catch the common sense.
Reg. all
Enjoykin
Enjoykin2017
Quote from: lacphong on September 22, 2016, 05:54:30 PM
Hi lacphong  !! :)
These are Stalker hand-drawn schematics of his BTG replication of Ruslan Kulabuhov.
BTG means non fueled generator - or Free Energy Generator.
* Контроллер БТГ.pdf = Controller BTG - main oscillator, logic control, push-pull control
* Контроллер ТТ.pdf = Tesla Transformer controller
* Логика работы контроллера ТТ.pdf = Tesla Transformer binding logic
* Обвязка драйвера = Mosfet Driver´s binding
* Преобразователь для питания ТТ или качера.pdf = Power converter or Switch power supply for TT or Katcher.
* Пуш-пул силовая часть.pdf = Push-Pull output stage
* Усилитель импульсов для генератора сигналов 1.pdf = Impulse Amplifier part 1
* Усилитель импульсов для генератора сигналов 2.pdf = Impulse Amplifier part 2
That all !!
