0 Members and 85 Guests are viewing this topic.
AlienGrey
Quote from: Enjoykin2017 on September 22, 2016, 06:57:40 PM
Hi lacphong  !! :)
These are Stalker hand-drawn schematics of his BTG replication of Ruslan Kulabuhov.
BTG means non fueled generator - or Free Energy Generator.
* Контроллер БТГ.pdf = Controller BTG - main oscillator, logic control, push-pull control
* Контроллер ТТ.pdf = Tesla Transformer controller
* Логика работы контроллера ТТ.pdf = Tesla Transformer binding logic
* Обвязка драйвера = Mosfet Driver´s binding
* Преобразователь для питания ТТ или качера.pdf = Power converter or Switch power supply for TT or Katcher.
* Пуш-пул силовая часть.pdf = Push-Pull output stage
* Усилитель импульсов для генератора сигналов 1.pdf = Impulse Amplifier part 1
* Усилитель импульсов для генератора сигналов 2.pdf = Impulse Amplifier part 2
That all !!
That's great but how do we look at them ?
Enjoykin2017
Quote from: AlienGrey on September 22, 2016, 07:07:05 PM
Open with pdf browser - so simple !!  :D
All: Does anybody have good experience and know to work with some Electronic CAD packages like Altium, PCAD. OrCad, AutoCAD, Target3001, Spectra, Topor and can make professional engineer schematics and design PCB layout/s on two sides (upper side must be ground plane) for all of these schematics ?
It will be real help to all BTG builders - all around the world !!
T-1000
Quote from: Enjoykin2017 on September 22, 2016, 06:46:17 PM
Nor one intrinsic electrical displacement or intrinsic charge displacement can produce Magnetic-Field !!
Here is something to think about - what pulsed high tensity electric field does to already present magnetic field? The proof is all over places, including GeoFusion sync effect replication you guys already experienced... :)
And to create that EM pulse on the Tesla coil/nanopulser it does not take much power but the result may be much greater when combined with ions from the air.
Cheers!
forest
How is ferrite ring transformer wound in * Преобразователь для питания ТТ или качера.pdf = Power converter or Switch power supply for TT or Katcher. ? What is the output power ?[/size]
NickZ
Quote from: T-1000 on September 23, 2016, 04:55:22 AM
Cheers!
   What I'm seeing is that even with what we are calling the "amplification effect", the bulbs are not lit to anywhere close to the lumin levels of normal grid powered bulbs.  This goes for ALL self runners. Including the Akula and Ruslan devices, and any other replication efforts. OU is not a prerequisite for self running!!!
  Stop looking for OU,  as OU does not exists, and never did, never has, and never will.
  So, what I get from studying about all this is, is simply to keep experimenting, until the moment of truth.
  Forget about input to output measurements, and focus on the self running effect, instead.
