0 Members and 158 Guests are viewing this topic.
conico
I need help! I am trying to replicate Ruslan 7. I already burned IRFP260 and put in place  IRFP460.
I believe i found a resonance for inductor coil at 32.47Khz, Vpp-572v on 293nF series cap, 3.48A at 24V from source, After the rectifier bridge I have a 16uF capacitor and a 100w bulb, 220v and  is DC 112v on it.
I do not know if this is resonance frequency but is a nice sine wave at 32.47 Khz.
My Kacher with 2sc5200 works just with a 10nF cap between collector and emitter and tesla coil is at 1.98Mhz.
I tried to turn on the device and the light bulb has diminished. I do not know what part of the grenade coil is on the ground.
To many schemes.
thank you !
NickZ
  conico:
  Please show a picture of what you are doing, or a video, if you can.
Just replacing the older fet with the IRF460 won't change whatever was causing the IRF260 to burn out.
  Are you using any choke(s) at the input to the yoke primary coil? If not, that may be your problem. As too much current will pass through, and the fets will heat up, and fry.
  You can try to connect the earth ground to the grenade's output coil, as well as to the 0.47uf series capacitor, both.
Try one side or the other of the output coil to see which placement works best. Or place the ground wherever it makes the bulbs light up brighter.
  The grenade's output coil needs a parallel 0.15uf WIMA cap on it, to increase the output. And also any other caps in series or parallel that increase the output, while at the same time having the earth ground in place.
  The inductor circuit off of the 3 turns yoke coil, needs a 0.47uf WIMA 1000v cap in series, and any other caps that help to increase the output. The WIMA caps are needed, not just any 0.47uf capacitors.
conico
 IRFP260 burn because it can not resist at 512v Vpp .
I do have a choke befor Yoke and a filter.
There are 3 caps 100nf/ 2000v in parallel total 293 nF in series with 3 turns coil and inductor coil.
I try to follow Ruslan scheme .
In parallel with 28 turns is just 2.2nf, more is not good, destroy the resonance.
I'll post a picture but the battery is low .
apecore
Quote from: NickZ on September 23, 2016, 10:22:09 AM
   What I'm seeing is that even with what we are calling the "amplification effect", the bulbs are not lit to anywhere close to the lumin levels of normal grid powered bulbs.  This goes for ALL self runners. Including the Akula and Ruslan devices, and any other replication efforts. OU is not a prerequisite for self running!!!
  Stop looking for OU,  as OU does not exists, and never did, never has, and never will.
  So, what I get from studying about all this is, is simply to keep experimenting, until the moment of truth.
  Forget about input to output measurements, and focus on the self running effect, instead.
Nick,
Of course will a high output at the end lead to a selfrunner.....  depending on the power what goes in?.... (should we limit the input power at 5A/ 24V.... and light then at least 200W full brightness bulbs?)
But i don't think we will get to that stage by only tuning our actual setups.
I being more and more convinced that the fact T-1000 has stated about the tesla pulsing and generating the BEMF on the grenade coil is a mayor key to get more output.
The fact that we have our results till now is a combination of good sync. setups and the effect as Hoppy describes as confirmed at my last video (HF kacher gate influence push pull)
We have as far if it isn't selfrunning created only a inverter.
So to make the next big step i think we have to be sure that our kacher system is generating BEMF at our grenade wich has to absorb it.
And measurements are required to see performance in this proces
T-1000 and Hoppy would spend some time and effort in setting up some of a measurement system,..... i am curious if Hoppy or T-1000 has made some progress.
There i also wants to participate in this....
Looking at al the systems wich are presented on the web by akula, ruslan, dally etc.,.... they are all just "flowcharts"...  and none of them has the complete information how it is working or even how its designe is defined.
If it was that simple to just duplicate a setup and start tuning a vew months then already lots of people would have succes.
So for me the next action is to see what comes out the ion wind action wich Hoppy and T-1000 have holding from the street.
On the other side,...  it is good that there are also persons wich continue with the tuning aspects wich will deliver the most efficient system setup for using later on with the optimal kacher tuning.
Together it will be a sustainable selfrunning kWatt system
conico
