0 Members and 158 Guests are viewing this topic.
AlienGrey
Quote from: Enjoykin2017 on September 22, 2016, 07:25:06 PM
Open with pdf browser - so simple !!  :D
All: Does anybody have good experience and know to work with some Electronic CAD packages like Altium, PCAD. OrCad, AutoCAD, Target3001, Spectra, Topor and can make professional engineer schematics and design PCB layout/s on two sides (upper side must be ground plane) for all of these schematics ?
It will be real help to all BTG builders - all around the world !!
Hi Enjoykin I don't recognise any PCB cads i n your list I use old version of Aries proteus if that's any help sorry about PDF I missed the links or they were blocked, ok now
but thanks for diagrams, sometimes it's best to make a perferated under board hard-wired links under-card to iron out bugs first before going for full proto PCB. from my observation.
A G
NickZ
   apecore:
   For one thing there is not one person that has actually made a true and accurate replication, exactly as seen in Ruslan's videos, or schematics,  so it's hard to judge all the different versions and various replication as to why they are not self running.
   I think that Geo may be close, and possibly so am I, but more and more tuning IS needed. As this is an extremely complicated device, and is not for the faint of heart.
   I am at the point that T-1000 suggested a long time ago, to allow for the self running effect, by connecting up a feed back loop.
First see if the system will run itself with NO load on it. Then progressively adding more and more load to the already self running circuits. That is what I'm up to.
  Conico:  Well... Thanks for that posting a picture of your device replication. A picture, is worth a thousand words.
  Welcome to this thread and to our ongoing tests and discussions, where some of us are focused on our versions of this particular TopRuslan 7 type of replication.
lacphong
Thank you Enjoykin2017 for all the translation.
itsu
conico,
nice setup.
QuoteIRFP260 burn because it can not resist at 512v Vpp
i am puzzeled by that, do you mean there is 512Vpp on the drains of these MOSFETs?
If you are using a 24V supply, there should be ideally 48V max there, with some spikes perhaps 100V.
So what does this 512Vpp looks like?  (scopeshot)
Do you use snubbering to fight these spikes? (if any)
Perhaps you should look into this lossless clamp design from verpies.
572Vpp looks a normal resonance voltage on the inductor/wima caps via the 3t secondary of the yoke with 24V input.
Itsu
Enjoykin2017
Quote from: T-1000 on September 23, 2016, 04:55:22 AM
Here is something to think about - what pulsed high tensity electric field does to already present magnetic field? The proof is all over places, including GeoFusion sync effect replication you guys already experienced... :)
And to create that EM pulse on the Tesla coil/nanopulser it does not take much power but the result may be much greater when combined with ions from the air.
Cheers!
I need «Relata Refero» for some people here !!
I have explicitly said «intrinsic electrical displacement or intrinsic charge displacement»
Intrinsic means inside electron shell !!
I said that because my dear Mr.Yuriy V.Leonov thought that «electric field displacement inside electron shell could produce magnetic field».
So in two words dear Yuriy V.Leonov think that source of Magnetic Field is Electric field which is totaly wrong and he was deluded by fact that around conductor exist Magnetic Field while through conductor running Electron Conduction Current.!!
Another question about known Laboratory fact is: «Why none magnetic field exist around conductor , near aboslute zero temperature , (several Kelvins higher) , while flowing Electron Conduction current of 1 x 106 A and higher ??»
How to understand that fact and how to explain what is going on in that case ??
Yes i have already explained in my earlier posts for those who are able to think without mind blockade.
Now we know from Tesla´s notes that he had used 12 Million volts as accelerating DC voltage for his massive copper primary. Right ?? Yes.
Then take a clean paper and pensil and calculate yourself electrons speed of bunch of electrons (unipolar impulse) with initial velocity voltage U=12 million volts.
Ve = 5,95 x 105 √ U (m/sec).
It is far higher than speed of photons or precise speed of electrical matter (electron filling) in free space.
Then find my earlier post where i have explicitly shown and calculated inertial forces and calculate forces with given Ve.
So will be fully clear that both electron filling matter (Electrical matter plus Magnetic dipole matter) will be released out of electron shell with giant inertia forces and will continue to fly with superluminal velocities.
Now RADIANT matter could be particular «intrinsic matter» of magnetic-dipole matter or maybe new monopolar aggregate state of uncoupled magnetic-dipole matter.
I have study Russian translation of very interesting book «Оккультная химия - Ч. Ледбитер» - an investigation by CLEAIRVOYANT MAGNIFICATION into the ATOM structure and some intrinsic Atom compaunds. Real researcher in Free Energy area should be read and make deep analyse of data from this book.
Reg.
Enjoykin
