0 Members and 385 Guests are viewing this topic.
T-1000
Quote from: NickZ on May 22, 2013, 10:31:33 AM
  What I've been following is the video, or videos, that Akula has made. That will not fool me, even though I may not understand exactly what is going on. Understanding the theory behind something is not always necessary in order to just replicate it. I was an AA electronic assembler, among other things, and can build most any electronic device, even without knowing how it works. And still make it work. Believe it or not.
  What I was asking help with is to understand what Akula is saying, as that I don't have a clue about.
You can make conventional device without knowing working principles just that does not apply to unconventional device. I will not wrestle with you in long discussion why, you may ask Grumage about this as he was engineer too  :)
To translate akula's words it will go to another missunderstanding as I am not interpreter even I speak English/Russian and my Lithuanian. The best thing you may get only when comparing what different people done so you may get the point...
MenofFather
Obviously I cannot help much on your personal build as I do not know what are you trying to achieve with yoke. You said you got 1kV pulses on primary and nothing on secondary of yoke and with impedance needed for 1kV pulse for transformer obviously is not on 20 turns of wire...
If 1000 volt pulses, then on primary must be capasitor about 0,5-4 mikroF to vibrate LC contur on it frenquency and then with pulses let say with 1 kiloherc put on  peaks sinus LC.  But I don't know exatly were is put pulses, so can't say concrete.
MenofFather
Translating words nothing give to you. On russian forums people good know russian language and can not replicate. Because it not give very much information how need make divice. Dally give much information, but it schematic very dificult and it disapear, so can not help that is important,, that is not important.
NickZ
   T-1000:
   Quote:
   "you got 1kV pulses on primary and nothing on secondary of yoke and with impedance needed for 1kV pulse for transformer obviously is not on 20 turns of wire"...
        End quote from T-1000
  Ok, that is obvious in a standard way.  So why is it that same coil windings are being shown in the videos by akula? I'm trying to replicate that, with what I know works. That is what I'm trying to do with my yoke.
Even though I know that the 12 and 12 turn center tap coil won't transfer much to a 3 turn coil.
But, akula is showing that it works, this way. And his fairly complicated driver circuit that feeds it, is not just a 12 volts output to his yoke.  So, I'm looking for the anomaly, as mentioned,  and the three turn coil is where I'm stuck at.
  It may indicate that 1000 plus volts input is not enough to trigger the effect. As there is little current with it, like one amp or so. It may take higher voltages, and higher amps,  like the 2.5 amps, and 25 volts. which I have not been giving it.
T-1000
Quote from: NickZ on May 22, 2013, 10:58:38 AM
I do not know where you did see these readings for 1kV as the low power source clearly indicates different voltage:
