0 Members and 93 Guests are viewing this topic.
conico
Somebody can tel me if this is a resonant point grenade coil and inductor?
What can i do next?
The Kasher is not start yet. In the movie  is 7amp from the power supply for grenade coil and inductor.On osccilloscop show: yellow
is from the serial cap with inductor and the blue is from the grenade coil.
I'm stuck with the resonants point of Tesla coil. The frequency of tesla coil is around 1750-1780 Khz. I can't change it more then 100 khz.
Thank you!
GeoFusion
Hi Guyz   8)
   Tomtech29,
:) well that is what we are here for, to help each other, but as you have seen in vid
I had to do that because to shut down most of the doubts,
Next time I will be placing it on a open field in backyard hopefully,
Will need to get a new 12V battery so i can get 24V clean without a problem with one battery getting depleted to fast
( old battery which has done alot of work over a year period,
if you charge it it will indicate it's full but it's fluffy charged ) so new one is needed.
Nickz,
the thyristors will be for the experimentation of Vasmus device or Roma Device ( ruslan also used it in one of his setups.
but that will be another chapter. But this very approach is one of them which is essential part in these Pulse devices
to charge and discharge cap rate for desired load.
Conico,
Hi,
Check this out
https://www.youtube.com/watch?v=vxxW6Xat4PQ
See how the guy determine the LC resonance on grenade.
after that To tune the Tesla to the same freq.
this is step one.
   Cheerz~
NickZ
  Geo:
  A back yard video showing a device that does not self run, is not needed. Nor will it proof anything but showing it working as an inefficient inverter.
  What is needed is for you to obtain another battery, a good one, that can provide you with the right amperage to continue testing to the point where the device will self run.  Your set up should ultimately run itself after just a kick start from a single 12v battery, as Ruslan has shown, or possibly even when using just a 9v battery.
   I've been waiting to see those results, even though you are not close to providing more out, than in. As that, as a prerequisite, is probably not needed for a device to self run.
   I also don't have two batteries to test with at the moment, and so I'm unable to use my PS for that purpose (feed back loop)  until two 12v batteries are obtained.  I imagine that even two smaller 12v, 4.5Ah batteries like Stalker is using, will do just fine for testing and tuning purposes.
   Again I'll state my opinion that the big bulbs are needed to allow for self running. As the bigger load of high wattage bulbs, is not a small nor unimportant detail.  And we can't really trust that Ruslan's earlier videos were actually self running, when using only a couple of the smaller bulbs as the load.
  I had previously asked you to show your device running one or more of the big 300w bulbs, with a grid powered one next to it as a comparison.  Not a 40w bulb, drawing 5A or so from your 24v, 15A PS.
  BTW: it did look like the device powered bulb was a bit brighter than the grid connected one.
   Good luck with your feed back loop.
   Thyrister is a rectifier, that can also help to increase and amplify to DC, the output voltages, when not using a PS for looping back to the input. Such as Roma or Vasmus may be doing. Ruslan and Akula I believe are using the PS for that same purpose, instead.
   I'm still very interested in knowing how Roma is able to do what he has shown, without all the complicated components, such as a nanosecond HV pulser, PLL, nor needing to use a yoke driver board to power a magnetic induction circuit. And still able to power 4000w loads.
apecore
Quote from: NickZ on October 04, 2016, 04:32:36 PM
You may use mine,....just come and get them.
NickZ
    Can you send them by air mail?
                                                 thanks,
    Using old worn out car batteries, may not be the way to go, especially If they won't start a car.
    I hate batteries in any case, they always fail, sooner or later.  I can show you my big pile of dead ones.
    Can't wait to have something that self runs, with no batteries, at all. Just a capacitor to kick start the device up.
    BTW:  How are your tests going? Are you seeing that it's not so easy as it first may seam?
