0 Members and 114 Guests are viewing this topic.
MenofFather
Quote from: NickZ on May 22, 2013, 11:14:29 AM
  Menof:
  Yes, the cap is needed after the yoke, as it takes the place of the noisy, or not so noisy spark gap. As we can see from his last video, there is practically no spark, or a very tiny visible spark, going toward the resonator coil. Maybe a big cap is not needed, just a smaller one of the right value. I was even thinking of using a leyden jar, as this has been done before, and worked well. I just haven't gotten there yet, but I will.
I mean not this capasitor. If you put 1000 V pulses, then capasitor C1 and brown wire in picture must is LC contur and it vibrate on self frenquency, and you must put 1000 volt impulses in resonance on sinus. Let say C1 and brown vibrating on 1 kiloherc, then pulses mus be on higher ampiltude exactly with that frenquency, exatly 1 kiloherc, or let say 100 herc, on each ten put pulse, that must be beter than 1 koloherc, I think. I see other pepole divice who get selfrunning and they seems speak about that or do that, LC vibrating on 1 kiloherc let say and you put impulses on 100 herc.
Hoppy
Quote from: NickZ on May 22, 2013, 11:32:58 AM
   As I can't clearly see anything, and much less the values on the picture of the power supply. Do they indicate what the voltage is at the center tap of the 12 and 12 turn coil coming from the driver circuit. As the drive circuit is being feed by 220v rectified Ac. or not?
So, the question is: what is the voltage/current value at the center tap, of the opposite wound dual 12 turn coil, or the value reading at the output of 3 turn coil. As well as what is the capacitor value that follows after the yoke, at least an approximation of the value to make that circuit resonate.  That is what I'm trying to do, at least understand enough to replicate what he is showing. The rest of the device is not rocket science.
Nick, I think the picture of the Akula PSU is throwing you. Its not an inverter, its a 12V / 10A PSU, so please do not try driving your coil from 220V rectified AC which is dangerous! The PSU that you can't clearly see in the video is running at 25V, 2.5A. I would think this is quite adequate for experimentation purposes.
MenofFather
MenofFather
"As the drive circuit is being feed by 220v rectified Ac".
Yes, mosfets if feeded with 220 volts. I think because he get that good result. Mosfets, I think is generate short pulses, so in other case curent can be very hight. So on 3 turns coil is about 50 volts, on red coil on tube is 50 volts or 100 volts, because on resonace voltage with capasitor (C2 in my schematic) can incress.
NickZ
  I'm not going at this blindly, as I've already shown previously, nor am I trying to replicate his last video.
So, don't get side tracked.  I'm hoping that you guys with all the toys, will help, as much as the guy next door is doing.
  I can only do what I can do, if this is not the horse that I can ride, I may have to look for another horse.
This device has already been sold, so It's probably just a matter of time before it's available at a price.  I hope.
  Menof: thanks for your explanation,  I almost got it.
  If I can get the light bulb to light, the way things are currently set up, then the rest is not so difficult to do. So, I'm trying to get at least that small light at the end of the tunnel, I'll then know what to do, after that.
