0 Members and 333 Guests are viewing this topic.
MenofFather
There how in Akula. Red amplidute can be not 220 volts, but 400-800, becaus it can vibrating on self resonant frenquency, and then pulses it make up, make up and amplitude make bigger and bigger.
T-1000
Quote from: MenofFather on May 22, 2013, 12:01:38 PM
Invert short pulses to 180 degrees and you will get what Romanov said over last 2 years... ;) That will match Tesla quote on some degree as you need higher frequency for getting better effect. Also Ismael Aviso did same if you like to compare.
Hoppy
Quote from: T-1000 on May 22, 2013, 12:14:06 PM
Invert short pulses 180 degrees with respect to what please?
verpies
Quote from: T-1000 on May 22, 2013, 10:44:40 AM
You can make a conventional device without knowing its working principles but that just does not apply to unconventional devices.
That's logical.
Even with conventional devices conventional working principles are used behind the scenes, e.g. metal wires conduct electric current when they touch, they form closed circuits, current loops create magnetic fields, changing magnetic fields generate voltage in conductor loops, current + resistance = heat, capacitors let AC pass but not DC, etc...
All of the above may just seem like common sense, but in fact it represents a body of conventional knowledge and conventional working principles.
Without them it would be very hard to build even the simplest circuit, e.g.: an ignoramus might not scrape off the enamel when connecting a light bulb to a battery with magnet wires, or he might use just one wire, or a nylon fishing line, or he might wind a coil with uninsulated metal wire (I did exactly that when I was a toddler).
T-1000
Quote from: Hoppy on May 22, 2013, 12:26:03 PM
Please watch this explanation for it - http://youtu.be/rv7C7YOetDY?t=29m28s
Ismael talks about shorting but if you apply short pulse opposite to sine wave on peak instead of shorting it goes even higher.
