0 Members and 138 Guests are viewing this topic.
Jeg
Quote from: nelsonrochaa on October 11, 2016, 07:47:02 AM
Hi Jeg,
I'm out in last months with some healthy problems but i appreciate hear that you like see what i write  thanks .
About your question :
Power is the rate at which energy is converted from the moving charges , so depending how one point is unbalance in relation to other  "ground".
On this particular system , the process of "kick" with high positive pulse the Tesla coil by the kacher circuit , create excess positive charge that attracts electrons from the ground, but the inverse could be happen to , because if the charge of the "kick" is more negative then ground and the unbalance exist in same way between the two points (ground and top of coil) creating the same difference between charges, attract more positive charges  .
So the circuit should be design in consideration this point's ; long antenna or longer ground  ? ;)
But of course this only my thoughts based in my experience and observation about this particular theme .
Have i nice day Jeg
Nelson Rocha
Thanks Nelson, i wish you to be strong and healthy again very soon!  :)
AlienGrey
Quote from: Hoppy on October 11, 2016, 07:52:36 AM
Interesting thought: http://www.sgem.org/sgemlib/spip.php?article8220&lang=en
Oh shock horror :) Don't let this frighten you, mains cable run under the ground and on pylons if your using the stuff it will attract itself to your system whatever the system, in fact your mobile phone and the new GAZ and LECKY intelligent system of transmitting your data and everyone else's in the road It will be more lethal than that system with a copper earth rod at the top of the garden. You could pull your floor boards up and insulate with plastic covering and filter the air outside, but you have the bigger threat of by our government of radiation and need to insulate your walls like a faraday cage  and what about all the toxic 'shit' in food like GMO crops that's rotting your guts and the genetic glue that's used to hold reclaimed meets together that accelerates deep vein thrombosis ? ;) https://go.thetruthaboutcancer.com/uls/?gl=582843892
NickZ
   Nelson:
   It's always a pleasure to hear from you.
   Although what you mentioned does resonate with what Tesla has written concerning the negative charge stored in the ground, and positive charge found in the air.  I'm wondering why Roma (video below) does not need any such ground line, at all, and his device can still produce as much output as any other self runner, which need ground lines to function. Nor is it dependent on geo/location to do what it does.
   I've done the tests using a capacitor connected to the ground also, and found no benefit, nor increased output from my device.
   What we need are specific and exact build details, not just more ideas, or hints. The thread is full of ideas, but, still not a single self running device.
   Have you changed your mind about letting us know about all the more important details of your self runner?
As that is what we really need. And also, have you been able to increase your output compared to what it was a year ago?
   https://www.youtube.com/channel/UC8fOJbjueHyD8BbUigXubmA
T-1000
Quote from: nelsonrochaa on October 11, 2016, 06:19:56 AM
I ear people talk about the theme of Geo localization , when Akula argued , be the reason to fail their demonstration in German .
Someone already think about the the difference of distribution of radon in different countries ?
maybe should think on that , and maybe Akula not lie when talk about that Geo localization problem ,to not have success in their demo in German .
Radon is present in different concentrations in ground and air and could be a source of power or not ?
Hi Nelson :)
The radon is much less to worry about when there are working Tesla coils.
Yesterday within a group (and GeoFusion was guest for a weekend in UK lab ;) ) I demonstrated how Tesla coil can produce high levels of radiation on specific frequency and pulse trains with discharge. The Geiger counter went 4000+ CPM on distance of 2 meters away from Tesla coil before I stopped circuit and was still showing that one minute lafer... That was very close to NMR effect just in the air. So it depends on what you are doing with Tesla coils. It may cure but also may kill depending on the voltage and frequency.
Cheers!
Enjoykin2017
Quote from: PolaczekCebulaczek on October 10, 2016, 11:23:16 AM
ahaa ,you are right, very interesting observation!
NickZ ,I was talking about extracting energy from atom is such a way that its not from radioactive decay, just extracting energy from electron orbiting around, simple EM energy, no alpha beta particles heavy shit, something that has never been done. However, if such a method (mixing volts amps? ) would exist then what would happen to atom if we slow down electron movement inside ? it would lose its mass? (mass converted to energy yet no radioactivity?!). Taking energy by radioactive decay is the brute force method, I was thinking about something more cleaver and subtle.
Extracting energy from ambient? so from what? bunch of atoms in air? aaa... mysterious cosmic rays? AFAIK T.Henry Moray (if his device was not an efficient radioactive battery/PSU activated by radio waves as some people claim) says that we just need a dam of some sort and put it in the way of cosmic rays/waves to slow them down to convert to EM energy, in Moray case it was a special diode made of some galena and something else, receiver for cosmic energy. The question is: can we build such a dam from EM waves by mixing them? how the cosmic energy interacts with weird grenade coils and kacher contraption?
PolaczekCebulaczek yes you are right my friend.  Real "energy" extracting comes from atomic shell (electron multy layer grid - that means comes from sum of mass electrons), which exist at very high altitude from the atomic core. How it look like: If an electron diameter is 1cm than distance till the atomic core is 1km. These are real experimental data obtained by E. Rutherford - i have only zoomed by factor 104r-105r to show you how it look like in realm.
Also you should know that in couple recent years, more than four hundred particles with a charge smaller than electron charge are found (crashing electron`s mass by accelerating and deccelerating collisions), and that mean, an electron charge is devisable - shared between many sub-electron particles.
So we have his Majesty - An Electron
I will repeat his main attributes::
1. Giant density = 15 000 ton/cm3,
2. The negative charge which can be shared among sub-electron-particles
3. Very strong love to magnetic force lines.
Most of all these facts give construction of an electron using some healthy logic statement:
At center of an electron — the strong magnetic mass (atomic core weight), and around it has stuck  several layers of elementary particles with electronegative mass, retained by attraction forces of atomic core mass.
At an outside layer electronegative mass, charge field of outside layer has not compensated by attracting field of central mass (atomic core weight), therefore this composing full-sphere behave like negatively charged body.
Forces which retain parts of electronegative matter are quite different in magnitude — for example for the first layer force will be stronger than the last outmost layer by 4 orders of magnitude.
Lokk with the mind  - central core mass , highly attracting core`s force fields at big distance order 104-105 r,  multy grid layers of electronegative matter with multy layer`s nodes setup in all repeled mode caused by strong Coloumb forces.
Now look - electronegative matter was trapped. Can`t fall in the atomic center core,  nor can run as fast as her's legs will carry her. As result we have pure balanced composite sytem of several forces with immense potential power (Coloumb power) concentrated in whole electronegative matter at distances 104r-105r from the central atomic core.
Now is clear where come "power" coming. Power in sense of Giant Kinetic Field released once we have disturbed intrinsic force fields balance (both of them - atomic core force field and outside layers of electronegative force field.
I hope you can understand because it is very simple. And MUST BE SIMPLE because the mother nature does not like complexity like human beings does.  :D
Well it is a 1st part of Show called "energy extraction" precisely will be Kinematic Mass Extraction because only the mass can bear the force. I dont know other case in nature.
Now about 2nd part of show.
If we realese "potential power" trapped in inner sphere of an electron what we will get ?
How it is possible ? Taking in account that central mass of an electron is 5 orders of magnitude densiest of an elctron - which i repeat have density 15 000 tons/cm3 and taking in account additional minimum 4-5 orders of magnitude stronger Columb force in intrinsic electron volume can you understand with what kind of Giant forces we have a deal accounting great number of electrons in multy layered grid of an atom. But it is not elese the end of show.
If we go further in matter organization what will be with forces in sub-sub particles (most inner sphere of an electron) and what will be with their immnse density by additional 4-5 orders in magnitude extent. But it is also not the end of show.
We going further and further deep in force and field matter untill hit Mather Nature Threshold of matter and force organisation. So we will come to some primary particles wuth so immense density that they can not be shared on much smaller particles because simple they does not exist further.
And now according to some hidden Vedic Cosmic knowleadge that primary Natural Threshold level is at *7 *seven* layers deep at Matter Realm until we hit primary source - primary partilce matter.
I must to admit i can imagine in my mind such giant immense densities and forces of Mother Nature Matter organisation. Remember Tesla´s rule in his MFT - Mass of Primary should be equal Mass of Secondary. Why should ?  ::)
Does the so called "Aetheer" exist and where to search ? I think Yes Aether exist not outside matter, in so called "empty space - vacuum" but in matter essence. So simple. And more there exist sub level of Aether known as Astral levels, further Astral exist Mental level and so on till the top 7th level in Matter Abyss Deep.
So all i have said - it looks like that an ordinary human being have potential possibility to rule whole Universe because that same Universe has "pack up" such possibility in every human being with high evolutionary consciousness - simple because only such super-human or super-consciousness can control such immense cosmic forces. So need boost our consciousness in Matter Abyss Deep.!!
I think it is a RIGHT WAY ON THIS PLANET HUMANKIND should go if want exist !!  :)
Reg.
Enjoykin
