stivep
Quote from: NickZ on October 13, 2016, 11:05:16 PM
  The part that you didn't include is where and how the "extra energy" comes into and out of the circuit.
  Any clues???
   I have a guess, that the capacitor has something to do with it.  No capacitor,  no extra energy?
   What do you all think?
Wesley's response:
1.potential between ionosphere and earth ranges from 150 kV to 600 kV
http://www.atmo.arizona.edu/students/courselinks/spring15/atmo589/ATMO489_online/lecture_1/lect1_global_elec_circuit.html
2.The maximum distance  between ionosphere  and earth is from about 60 km (37 mi) to 1,000 km (620 mi) altitude
https://en.wikipedia.org/wiki/Ionosphere
3. 600kV divided by distance 60km=10kV per km=10 000V per 1000 meters =10V per meter .
Note: we only talking now about  electrostatic potential.!!!
4. if the wire of AN "ANTENNA" with plate at the end or metal insulated roof is placed at 5th floor of the building where each level is-5meters  than 5x5=25m x 10V=250V
5. the size of the plate stays about  energy density of that electrostatic  charge but at the time of discharge it  determines  reactive value of capacitive  and  inductive components of AC impulse.
Note:size of plate is strictly depended from HV potential. The higher is the voltage the smaller or "close to none" is the size of the plate.Think of it that TK plate was big coil, and TK  storage flywheel was rotating 20kW electric motor. in addition to bank of capacitors of pretty nice size ( non polarized)Think also  that this motor (in tent) did not have any load connected to the shaft , that means- after initial start the energy to run it is
QuoteAt no-load the machine only needs to overcome windage loss.
https://www.researchgate.net/post/What_is_the_power_consumed_by_a_50_hp_motor_at_no_load_condition
Note: the higher is the voltage the ionization of the  air= change of electrical properties of the air =the more friendly is the environment for such interaction
due to air/air components  reactive response.
( I can only say as much)
6. we do not have to discharge it.
7. we may determine delta T of subsequent  recharge if discharge  happened or if we used potential difference  by our self.
8. We may add extra bank of "big" capacitors ( Tariel Kapanadze- tent presentation) to store energy.
9. this energy is our free to use bite that could be transformed to HV of 10kV and more. using e.g avramienko two diode bridge or https://gaming.youtube.com/watch?v=oZpeHwVJtF4&list=PLZAFePZGzdTHYwTEZwc2mI79h-skCnEb9&mweb=1
or
https://en.wikipedia.org/wiki/Voltage_multiplier
10. the bigger is  difference between  earth and our HV electrostatic bite the  more attractive  it is  to electrons flow and electrons  inertia.
Note:whenever I use word Bite it means  attractive force, for electron flow and  when chopped  with nano/pico impulses it stimulate electron inertia
Note: the power of each impulse is very significant http://www.vishay.com/resistors/pulse-energy-calculator/
http://www.radartutorial.eu/01.basics/Duty%20cycle.en.html
http://www.dtic.mil/dtic/tr/fulltext/u2/a229381.pdf
and this was 27 years ago !!!!!
QuoteOur  experiments  have  shown  that  the devices are capable of handling currents in excess of 1 kA during pulsed operation.
QuoteThe  gate driver  is  only  required  to deliver  current  (and  power)  during  the  turn-on  and  turn-off  transitions
QuoteThe transformer is increasing the voltage by a factor of 20 and is charging a section   of   High-Voltage   (HV)   coax   cable   through   a resistor   to   avoid   oscillations.
QuoteThe   HV   coax   cable   constitutes  a  transmission-line type  pulsed  power  source with  an  impedance  of  50Ω.  It  is  capable  to  produce  a square  wave  pulse  with  rise  and  fall  times  of  less  than  a nanosecond (ns). The transmission line acts as a source to investigate   ultra-fast   surface   flashover   phenomena   on dielectric  surfaces.  Since  flashover  processes  develop  in the ns time
and sub-ns time scale, the transmission line is an  ideal  source  for  these  investigations  for  the  following reasons: If   a   discharge   develops,   the   transmission   line   can deliver  a  surge  of  energy  very  quickly  to  enable  the breakdown  process  to  fully  develop  and  be  readily detectable. After  the  breakdown  process  is  fully  developed,  the energy   content   of   the   transmission   line   is   quickly depleted   (in   about   10   ns)   and   arc-damage   to   the dielectric surface is avoided.
does it ring the bell?    Tariel Kapanadze presentation to Wesley in Tbilisi. He used ready to  use HV train pulse generator from gas heater delivering normaly spark to ignite gas . and before in green box he used spark gap for impulse generation.
The conclusion is that  such generator is not critical.http://www.pwrx.com/pwrx/app/10561.pdf
Note: train pulse generator: http://www.keysight.com/en/pd-1871912-pn-N5182A/pulse-train-generator?cc=US&lc=eng
11. two ways of utilize of that HV :
a-  nano or pico pulse  to create  electron inertia -at best  when in "sort of resonance"( hee I did not know how to name it yet)
      than  think of child on the swing
where   you just keeping swing on the maximum of the  swing amplitude adding just minuscule amount of energy to compensate losses.
b.You may also compare it to  15 girls pushing at first car and than  when in motion  only one finger of only one girl can be used to compensate the losses..
12. both  11a and 11b are talking about energy storage similar to flyback transformer ( with the gap on the core) or  mechanical flywheel .
13. the bottom line is to eventually couple to energy of another source that we do not have to pay for using described by me above  sketch of possible mechanism utilized by TK, akula  ruslan etc.
To better graphically  express it: think of big pipe with water  coming from the river and the only energy you need is the energy used to open the valve.
The source of additional energy
I have in mind but At this time I'm not in comfort of sharing it with public but  I have willingness  to do so with pleasure.
Note: Electrostatic concept devices  such as TK /Ruslan e.t are for me side of interest from scientific point of view.
That means I do  try to understand it but in my free time. My main research is in particle physics.
I'm not interested with fame nor money nor any other benefit
I want to use  rest of the life I have, to have  as much of pleasure as possible coming from  my involvement in science.
Wesley
PS I"m thankful to Stefan for taking care of nuisance individuals on this forum
Zeitmaschine
Quote from: stivep on October 14, 2016, 12:01:59 AM
An alternative conclusion could be that neither the pulse generator from gas heater nor the green box spark gap is really necessary (and thus not critical) for the device to work, hence those parts are most likely just decoys in order to point people in a wrong direction. ::) :)
stivep
Quote from: Zeitmaschine on October 14, 2016, 07:40:05 AM
if it is  so.....? than, how do you support your "alternative conclusion"?Zeitmaschine?
Everything people say in form of one sentence statement is  similar to "dog barking in the dark" heee :)
You can hear the sound, but we do not have confidence of expression and reasoning of that barking, till the dog "say" more
but even so, it is interesting to respond to your comment,  - we may  also say that if   sources  of energy used by TK
are for you most likely
Quotejust decoys in order to point people in a wrong direction
Than another  energy source that could be easily hidden inside of TK device is Beta emitter where  its energy is converted to electrical DC  current and than to AC HV impulse.
So thank you for your comment Zeitmaschine BUT YOU MAY ALSO ASK IF THERE IS THE PRESENCE OF BOTH FACTORS AT THE SAME TIME
1. electrostatic potential difference
2. isotopic in nature stimulation of ("energy free of charge" - FE)
Note: emitters Alpha and Beta differs  with "power level"
The unit of measure is eV
Alpha is in within the range of MeV       (Alpha particles a particle identical to a helium nucleus.) https://en.wikipedia.org/wiki/Alpha_particle ( helium is part of air) :) :)
Beta is in within the range  of keV
So Alpha is  enormous  in its  power compared to Beta.
As far as properties of radioactive emitters:
1. whenever  you have gamma you also have x-ray
2. x-ray power level is  in range of eV     ( eg. 50eV) and it is usually significantly visible on the graph.
3. Alpha and Beta emitters are  "particle throwers" however  that particle  interaction with  ... is important to us.
4.  Neutron emitters  can be:
a. in form of naturally decaying isotopes
b. in form of neutron guns or neutron emitting devices.  https://en.wikipedia.org/wiki/Modulated_neutron_initiator
Note:
Neutron:
https://en.wikipedia.org/wiki/Neutron
- neutron can change "any" matter
-Neutron  can interact with nucleus of an atom (e.g copper) and "make it" to start decay  ,that means "turn it" to isotope
-can the neutron gun be made  at home?
Here is how you would do it:
QuoteTake a lead tube and plug one end of it up with a lead plug.
Inside the smoke detectors (if you've got one), there is some Americanicium-241, I don't know where it is exactly (there was one time they did it on a podcast in Kitchen science), but remove it and place it inside your lead tube. You might try using a Geiger counter to find it (if you've got one :D
Plug the remaining open end with another lead plug, but drill a very small hole all the way through this one.
Place an aluminium foil over the end of the tube with the hole and hold it in place with a rubber band.
REMEMBER: the aluminum foil must cover the hole, this is essential to its operation!
CONGRATULATIONS! You've just made a neutron gun!
http://www.thenakedscientists.com/forum/index.php?topic=19985.0
type of neutrons:
-fast neutrons
-slow  thermal neutrons
Note:  we intentionally slow neutrons with some plastic to increase their probability of interaction with matter. Beryllium  metal is also used in neutron production process .
Wesley
NickZ
  Any clues???
   Stivep:  My quote above is still waiting for an explanation. And not the one from our current science books, as they don't have a clue.
   However, the not so secret dark government underground facilities may know more than just some clues about all this.
As well as do the ET's which are starting to show up everywhere, in closer ranges than was observed previously.
Could mean exciting times for us concerning the subject of free energy in the near future. And also to help us avoid poisoning the rest of the world with this nuclear crap, and contamination, which is already at historic levels world wide.
T-1000
  Any clues???
The old akula video https://www.youtube.com/watch?v=-rALEpvBQig include that. Obviously the video is in Russian and you need tech interpreter for it...
