0 Members and 47 Guests are viewing this topic.
boonk
Quote from: AlienGrey on October 15, 2016, 09:45:55 AM
Be aware the maximum breakdown voltage of the LM317 is 37 Volts !
and the NE555 is quite a slow device if trying to emulate a coils fly back pulse electronically, I made something like this to test LOPT's years ago and it wasn't too efficient and it would draw loads of current, just an observation.
A G
-He repeated the test with the ground:
https://www.youtube.com/watch?v=5nhqaRyp9DI
circuit principle for Kapanadze:
Tomtech29
Hello
I would like to share with you some information that some time was presented by:
Sergey STALKER
specifications apply to the construction of the coil:
his calculations show that?
https://www.youtube.com/watch?v=pNFXlo5jv4g&t=0s
- section wire 4 inch and 2 mm (4,2mm) with insulation.
- copper wire for good conductivity "clean"
- copper thickness 2.5mm
- the size of the coil with insulation and a cross-section of the pipe! 50mm. (51mm)
- 1/4 wave inductive 171 mH. windings on a carcass 268T.
- cable length 45 meters.
- all parameters are in the course of the project that systematically ,subsequent stages of the properties of the coil and the frequency you can see here:
https://www.youtube.com/watch?v=ObQFTTJimuI
his initial assumptions set the frequency on the closed circuit coil ,and important to the state of the amplitude does not change under the influence of the hand on the coil.
In this case: 1.100Mhz frequency range from 830Khz/ This range is intended to low-frequency push-pull.(83-110Khz)
- while the upper frequency range 4.63Mhz
The rest of the analyzer showing the peak at 83 Khz the selected harmonic uses Running square.
I'd asked  You for an explanation of how the frequency of 83 kHz translates in decibels ? how both frequency "overlap" 4.63Mhz
I lost the thread what are these selected frequencies
84,2
87,4
90,8 Khz with a tag on it !
94,5 Khz with a tag on it !
I am very curious which reflects the kind of wave:
it would be very good as anybody has corrected the MEASURE so that everyone can benefit from this (still a lot I have to learn about the analyzer) :D
We see what still eventuates...
NickZ
  Yes, all good but no self runner from him.
  Is that really any different than what we previously tried to do, with our signal generators?  Yet, not finding any correlation to extra energy at the maximum amplitude frequencies.  He has NO earth ground line attached while tuning, either.
And the grenade's former tube (50mm) is not the same size as the sink drain tube that Ruslan is using, but bigger.
   He has made both the grenade output coil longer, as well as the inductor coil longer also. Why?
   Stalker has made and shown numerous circuits in the last couple of months, yet none are self running.
  His HV circuit is producing a tiny spark, which does not even stream.
  If I'm wrong about any of this, please let me know. As these are only my questions and observations.
Tomtech29
Quote from: NickZ on October 16, 2016, 10:07:59 AM
Hi.
I think you that to conclusions too hastily (I get the impression that everything comes down to a different theses and actions in such directions disclaims any sort of chance of success because this is not done,by "Ruslan")
and tell me what you have? thumbed his nose at all and many of his generosity
We try to imitate structures with elementary knowledge.
You ask me questions why he uses another coil length ? Wow - no I have to admit that my shoes fell
where you're going with this question ?
How so I look back it also wonder as Dally obtained the efficiency and matching parameters when so imprecise construction This looks like the coil of a fully random.
- Here you have the full spectrum of how to distinguish ratio calculations and capacity as well as the wave length and support "as the books they write".
And you have  to blame oh no self runner. Such is the nature of government
the flow of information is such and no other and substitute people what is the interest of curiosity and do not eat their greed.
To keep up with new ideas must not only observe Why not also try perhaps you become a lot more.
So far it so we'll see what next.
NickZ
  Tomtech:
  As you know I don't understand Russian, and my questions were not just directed to you, but to anyone on this thread that can answer them, and can understand what Stalker is saying, or doing.  Not am I blaming him for not showing a self runner, but, I do consider the outcome of his previous circuits, yet know it's all part of a process.
   Where am I going with questions like? Why he would change all parameters, of the grenade coil, induction coil, Kacher, etz...
are important considerations, to me. Maybe he has a reason, to do it differently, and that is why I was asking.
   Akula did not tune the same grenade coil that he used on his device, to show how it's tune for resonance on his video, he used a different coil, instead.  Why not show the same coil, and how to tune it? Showing it's exact resonant peaks, as Stalker has done.
   I mentioned that we had done some similar tuning, using the signal generators, to find the highest amplitude at the output coil. You were one of them that worked on this, if I'm not mistaken.  But, the outcome did not work out very well for us, when trying to match the circuits to best resonant peaks.  And, I'm still wondering why, and was wrong with what we did.
That's all.  So, don't let your shoes fall, as it's not such a big deal. As I said, it's just my observations, and questions.
