AlienGrey
Quote from: AlienGrey on October 18, 2016, 12:57:10 PM
It's just Quackery !
How does sap travel up a thee to feed it's canopy ?
How dos a salmon swim up river
What did the germans manufacture in Peenemunde Poland and how did it fly ?
AG
dewetw
Conico an inductor will have less inductance with more space in between the conductors. The wires we are using to wind these coil have plastic around the conductor. The thickness of this plastic will influence how far apart the conductors are and hence influence the inductance even thou is seems to be wound in the same way as Ruslan's.
Also, the granade is actually two coils opposing each other in their magnetic field and therefor does not behave like a stand alone coil, especially at different frequencies. All inductance meters uses some ac frequency to measure the inductance of a coil. Given these parameters I think it is save to assume that you are not using the same type of inductance meter as Ruslan and yours most probable measure using a different frequency than his. This too will then lead to different measurements.
Use a scope and frequency generator and a CT (current transformer) to determine where your garnade shows zero current even thou a voltage signal is applied. Then tune your tesla coil to that exact frequency. It is only at this zero current frequency that you can super impose a voltage without to much resistance.
With this high impedance point in mind: Now if you have a current already flowing at its peak in the coil at a low frequency (8 - 30kHz, design dependent) and superimpose a voltage at the high impedance frequency on top of that current and use a diode to catch only the positive HV sitting on top of an already positive current cycle the wattage must be (1/2Vhv+Vcyc)xAcyc which is more than just Vcyc x Acyc
This is why tuning is so important and resonance also, but not the design specifically. For this reason there are different looking devices that are all self runners. Have you ever notice that most designs use a ferite core from a TV? This is because the original working device used this and everybody just copied that consept. I bet the original design was down by someone that was involved in TV repair and had these laying around and thus used what was at hand. The clue here is the TV - where we find one signal superimposed onto another. Same reason why Ruslan figured it out so quickly (3 weeks if I remember correctly, his own words) - he owns and operates his own radio station and it is clear that he is versed in electronics. I have to conclude he has a background in radio engineering - here too we find signals super imposed onto carriers. PS: if the ferite was so important then how did Tesla himself do it, did he take apart his TV? In both radio and TV impedance matching is the key to max signal strength (aka power transfer). And to achieve matching you have to tune for it specifically.
Take a radio, tune to a radio station and cut off the antenna, see what happens? You lose the signal because of the mismatch you created. So lets all stop living in the land of the mismatched and lets tune in to the positive super imposed.
Hope this helps. Happy tuning :-)
dewetw
1) Hey Spinach (Sequental.9), where is your video? No one is reading your junk, your are like a dog barking or a baby crying - we get us to it after a while, back ground noise.
2) Hey Spinach (Sequental.9), where is your video? No one is reading your junk, your are like a dog barking or a baby crying - we get us to it after a while, back ground noise.
3) Hey Spinach (Sequental.9), where is your video? No one is reading your junk, your are like a dog barking or a baby crying - we get us to it after a while, back ground noise.
4) Hey Spinach (Sequental.9), where is your video? No one is reading your junk, your are like a dog barking or a baby crying - we get us to it after a while, back ground noise.
5) Hey Spinach (Sequental.9), where is your video? No one is reading your junk, your are like a dog barking or a baby crying - we get us to it after a while, back ground noise.
6) Hey Spinach (Sequental.9), where is your video? No one is reading your junk, your are like a dog barking or a baby crying - we get us to it after a while, back ground noise.
AlienGrey
Don Smith is no longer with us. and are you still trying to sell QEG \ QEF none disclosure part ownership contracts ?
who wants to buy into negative equity, when it goes tits up you won't be able to discuss it with any one.  ?? ??
SolarLab
F.Y.I.
FREE ENERGY [Frolov]
http://www.intalek.com/Index/Projects/Research/FreeEnergy.pdf
Source:
New Energy Technologies, Issue #2 March  April 2003
Alexander V. Frolov, Russia
Faraday Laboratories Ltd
http://www.faraday.ru, tel/fax 7-812-380384
Selected Excerpts:
Page 12 - "So, in orthodox physics there is the unchallengeable
formulation: the work of potential field on closed
trajectory of motion is equal to zero. Yes, it is right for
only case: if one part of work is positive (the
acceleration) and another part is negative (the
deceleration).  But one part of the trajectory or a part
of periodic process with the negative work can be
excluded by different methods: by means of spatial
superposition, pulsing mode and change of interaction
polarity or by the screening of electromagnetic
interaction."
Page 14 - "Let's consider some quite real (to my mind) examples
from the history of development of free energy
technologies. Nikola Tesla's investigations are not well
known to modern scientists and engineers. In his
works on development of wire-less telecommunication
Tesla used flat spiral coils as a secondary winding of
transformer. The magnetic field of such coil is radial
and it is placed in the plane of the coil. In 1995 the
author of this article experimented with similar flat
spiral coils. I have to claim that when such coil is
operating as secondary winding and the solenoid is
the primary winding of the transformer then we can
measure asymmetrical mutual induction, i.e.
connection of active load (lamp) to output circuit of the
transformer is free from input power in the primary
winding. It is the simplest example of technical
realization of the asymmetrical cause-effect connection,
described by Kozyrev in his
theory of active properties
of time."
... "creation of energy" is possible in theory...
"Another Tesla's invention is his resonance transformer.
Modern electrical engineering describes transformer
with forced electrical oscillations and radio engineering
considers operation of resonance systems mainly. Tesla
put the question on transformation of power in
resonance transformer and by this way the efficiency
can be more than 100%. With high frequency currents
and high power level Tesla used single-wire terminals
as loads, i.e. the lamps and other single-wire receivers
of power (motors) were powered from high frequency
changing electric field. Such single-wire terminal does
not consume any power from primary source because
it uses the change of potential in point of connection
to conductor (let's note also that for maximum efficiency
this point of connection should be one of the maximums
of standing wave).
The notion about "free vibrations" belongs to Tesla and
this term describes sinusoidal oscillations in electric
circuit that is created after short non-sinusoidal
impulse due to real vibrations of the free electrons.
Resonance mode of the free vibrations can be the real
way to excess power output."
Page 15 - "The standing waves of electric field
that were observed by Tesla during thunderstorm brought him
to conclusion about possibility of the system to power
remote energy consumers from energy generator
without any transmission lines and without radiation
methods. He assumed that it is necessary to create
special standing wave of electric potential (or variable
in time electric potential field) around the generator,
then the unlimited number of loads (lamps, motors) in
area of this potential field can be powered if they are
tuned in resonance with oscillations of the generator.
Let's notice that in each receiver the power can't be
more than power of this generator but it is possible to
install many independent "receivers" without mutual
interference."
"The modern investigations on these problems sound
as sensation, because Tesla's works are unknown for
the modern generation of scientists. Of course, modern
electronics components and the tools facilities allow
to create real "miracles" in comparison with the past
age experiments.
For example, engineer Avramenko
described his work on single-wire power transmission
in Journal of Russian Physical Ideas, 1991, No.2, and
in journal "Inventor and rationalizator" 1992, No. 5, 6.
The light bulb (or ventilator) was used as load of the
single-wire power transmission line. This line can be
made of high resistance material, for example,
tungsten, but the power can be transmitted without
heating of wire! It is possible to say that in this
experiment a wire does not transmit power from the
generator to the load, but the wire is the conductor of
information signal, which is created by polarizational
current opened and described by M. Faraday."
"It is not difficult to repeat the experiments with single-
wire line: it is necessary to place two diodes on the
end of a line, which is connected to secondary
winding's of high voltage transformer (I used television
set high voltage unit) by such a way that different poles
of the diodes are connected to the line, Fig.3."
{{{ see full article for Figure 3. }}}
... the electric potential field can create non-
compensated force in the system and to
produce a work without any power input.
"Of course, high frequency
and high potential allow creating high power in the
load."
... the efficiency of "electric system can be
million to one"
Further information and study:
The Work that is Created by Means of Potential Field
Report on the International Conference "New Ideas in Natural Sciences",
St.-Petersburg, June 1996
Alexander V. Frolov
Scientific Expert of Russian Physical Society
P.O.Box 37, 193024, St.-Petersburg, Russia
http://energythic.com/usercontent/3/2009.11.02_EN_Theory_EnergyThic_Work_Created_by_Means_of_Potential_Field.pdf
The Application of Potential Energy for Creation of Power
By Alexander V. Frolov
http://www.alternativkanalen.com/appl.html
POWER FROM POTENTIAL Theory and experiments Frolov
http://www.eskimo.com/~bilb/freenrg/frolov1.txt
http://www.keelynet.com/energy/frolov1.htm
Alexander V. CHERNETSKII  -  Self-Generating Discharge Plasmatron
http://www.rexresearch.com/chernetskii/chernetskii.htm
After reviewing the above papers; study "Ruslan's" generator; hopefully the "how it works" will become less of a mystery.
Good Luck and have a very nice day!
FIN
