0 Members and 63 Guests are viewing this topic.
AlienGrey
If it's connected to the grid it will just overheat and the core will saturate and the lacquer will turn to smoke and it will burn out and probably start a fire. I've seen the guy in the lab coat do it and he spent 2 days rewinding it with epoxy to hold it together before the fuse blew! ;)
MenofFather
Quote from: NickZ on October 23, 2016, 10:39:46 AM
   Does he explain why changing the windings can make the AC signal change to go in one direction (DC?)?
   Does any one know how to make the Kacher's output AC signal go in one direction, to the antenna coil?  So, that we have unipolar HV DC pulses, instead of AC pulses?
   Isn't that what Tesla had mentioned is needed, instead of a HV AC pulse?
Seems what he not explain. I have now mobile internet and can not wach again that video.  But I not think, that winding direction is important. Ruslank Kulabuhov says, that work and then all layers in one directionand and  then two layers to one and 4 to other direction.
About Tesla... Tesla get pulse on primary coil of Tesa coil, but not on secondary.
Zeitmaschine
Quote from: AlienGrey on October 24, 2016, 07:40:35 AM
Because they are not stupid
Not stupid, because they get already payed for doing blurry OU videos without any real value? ::)
NickZ
  Perhaps Adrian can be nicely asked to further explain his circuit.
  We can see on his video that his Kacher is just a simple circuit. So, that gives me further confirmation that even with just using a simple Kacher circuit, can produce a self runner, although not a very strong one. As it looks like his bulbs are barely lit with about 25w on each bulb, even though he states 70% brightness, and uses a long Kacher secondary coil, twice as long as Ruslan's HV secondary.  I see only 125w worth of light, and not 300-400w.
   He does need to find a better camera, and hold it steady. In any case, it's a good start, which none of us have been able to achieve, so far.
   T-1000, Grum:  I've been very busy lately with other things, and have also had some problems with my Kacher circuit which I've been trying to correct. But, I'll be calling on you soon.
justawatt
Quote from: Sustainable on October 22, 2016, 08:45:32 PM
I found this guy from brasil and he seems to have replicated the devices from kapanadze, and don smith . Any thoughts?
https://youtu.be/z2clyxuHkpg
hello everybody
According to this inventor , the free energy that he is generating is from " Muons".
" patents.justia.com/inventor/gerson-silva-paiva "
He has filed atleast 8 patents in 2013 now most of his patent is published in 2016 or he got patent.That is the reason he has comeforward to share his device through youtube.
According to patent ,the circuit is 90% similar to kapandze patent. shared photo for your reference.
Now working of the his device.
Summary:
The voltage output from the muonic generator follows a function of 4 variables:
V=F(f, D, N, L);
where f is the frequency of the oscillator, D is the diameter of the coil, N is the number of turns of the coil and L is the length of the coil.
A commercial battery of 9 V and 0,1 A (therefore, of 0.9 W), which was connected to a device as in FIG. 1 with an outer coil 7 with a length of 25 cm and with a copper wire of 3 mm and a radius of 5 cm. The inner coil was also made of copper, with a wire of 5 mm and a radius of approximately 4 cm. A "chip" or integrated circuit PIC (32) ("Programmable Integrated Circuit") is programmed to oscillate at wavelength λB above mentioned within the oscillator 4. Only as an example, one can use a Hartley type oscillator. The "PIC" 32 already pre-programmed to emit the λB above defined is inserted as in FIG. 5. The load utilized in this experiment consisted of 15 110 V 60 W bulbs, therefore a total charge of 900 W. Highly surprisingly, all the bulbs lit up with irradiance and normal brightness to the naked eye.
This resulted in a COP of 1000, thanks to the capture of atmospheric muons.
As indicated above, it is an essential characteristic of the present invention that the oscillator 4 is tuned to the frequency of the wave function to capture the energy created by the decay of muons in the centre of the core 12 in relation to the above equation λB=n×λC=n×5.88×10−23 m. Empirically it was established that λB should be around 5,88324456243×10−23 m. This wavelength is obtained with great precision by way of a "chip" or integrated circuit PIC ("Programmable Integrated Circuit"), which is programmed to oscillate at exactly this wavelength. The programming of the integrated circuit is done by way of a PIC commercial programmer.
flowchart attached
https://patentscope.wipo.int/search/docservice_fpimage/WOBR2012000382@@@false@@@en
So according to him the frq of tesla coil should be tune to muons wavelength =======" λB=n×λC=n×5.88×10−23 m"
