0 Members and 46 Guests are viewing this topic.
justawatt
NickZ
  Justawatt:
  I wonder if Kapanadze knew about muons???  I don't buy it, at all.  Patent or no patent.
  Now what?  Who will build the muon decay device in their house...  Not me.
   Muon - Wikipedia
  Sequental.9: If you won't build the device that your talking about, first,  no one else will,  either.
  We are now just skipping over your posts, your insults, and you.
  Keep it up, and see what happens...    Remember Enjoykin...
Jeg
Quote from: Sequental.9 on October 19, 2016, 05:26:44 PM
Take a small 12 v ac transformer and cut it in half take out the secondary coil and weigh it ! The replace it with one the same weight 10 times thicker ..
Hi S9. Don't want to sidetrack this thread so in short.. Same weight 10 times thicker so that means10 times less turns? Sounds interesting. Thanks.
Thanks Marek for sharing this paper. A really nice work ;)
Hi Justawatt. This kapamadje supposed  circuit has been published again before some months from JohnK1. The two coils at the air transformer were of 1/2 and 1/4 wavelength. The former gives at its top a node (high current), the latter an antinode (high voltage). In case you are going to mess with it. ;)
T-1000
Quote from: NickZ on October 24, 2016, 11:01:49 AM
  Justawatt:
akula is calling that as positrons. There is whole zoo in terms being used for same thing... :)
To avoid confusion it is more easy just say 'ions'. Then things get more clear.
P.S> Link to the patent application justawatt just mentioned above - https://www.google.com/patents/WO2014161057A1
(My comment - False people hopes to claim ownership what belongs to N. Tesla, heh.. )
Bat1Robin2
Look into the piece called the (summator).  It is explained as a modulator type of device however. There is only a small difference between a capacitor and a battery. We built one in 8th grade class(that was 30 years ago) out of 2 layers of dissimilar metals and a chemical or 2. I just want to say how similar it looks to a home made battery.  They now have lithium batteries only a few millimeters thick. The ease of hiding a battery with some serious power is completely possible.  He probably accidentally converted a capacitor to a battery by some kind of chemical between layers and then was fooling around with it and charged it as a battery and all of a sudden it self runs. ( but only until the battery dies) Then video goes viral and he decided to keep up the illusion.  Method of starting is very easy to engage a relay with an external battery to allow the (summator) battery to take over and watch the device run a little while.  These bulbs can appear to be fully lit at maybe 30% power of full brightness. So output power is way overestimated. If he would convert his oscillator to an integrated circuit style he could start it without a relay by powering the chip vcc for a moment like ruslan does this gives a better illusion. Remember the best illusions are done with redirection. Look at all the tesla stuff that radiates power in every direction. No more possible than running a solar panel from a light bulb to self loop.  Muon generator lol.  Muons arrive at 1 muon per square centimeter per minute. So what is powering it for the first 30 seconds before a muon hits it. If it where muon powered it would start on its own. Extraordinary claims require extraordinary evidence we just have not seen. Run it for hours and monitor voltages then you will see quickly what is changing. Meters can pickup voltage drops quickly. Thats why they avoid them and just run some bulbs quickly and stop the video.
