0 Members and 140 Guests are viewing this topic.
Hoppy
Quote from: NickZ on October 26, 2016, 12:49:26 AM
  The diode may be limiting the output from the PS to only 3-5A, instead of 15A that the PS can provide. So, I would recommend that you should try a bigger 15 amp diode, instead, or one that matches the output levels of your PS.
Nick,
The diode will not limit current from the PSU. If the load demands 15A then a 3-5A diode will be overrated and burn-out.
Hoppy
Quote from: URFA on October 25, 2016, 05:33:44 PM
"You have to learn how the electromagnetic waves are acting in a high frequency transformer system. Then you have to bring the Kacher and the receiver coil in resonance  When you are ready then, Only then you can build the small circuit with the mosfet to hit the positive or the negative phase of the wave.(Like Pomah) Or vice versa. Hit the positive  phase of the wave to receiver(Grenade coil)  with kacher or tesla coil.(Like Ruslan or Akula) Thats it!!! You can see of yourself the overunity you wish."
Regards.
https://www.youtube.com/watch?v=td0wvG6ZGfE
Ibrahim.
What is the current drawn by your lamp load and the average voltage across your lamp load?
Jeg
Quote from: T-1000 on October 25, 2016, 10:54:23 AM
Talking about replications I was tipped on something in Ruslan videos which relates to the grenade coil output in https://www.youtube.com/watch?v=ZZrB3pCRu8s#t=502
Ruslan was charging output caps (around 1uF) with up to 1000V from grenade then taking out power with impulse step-down inverter (~15kHz) to the load over ferrite ring, diode bridge and output caps.In short, the inverter just like in Don Smith circuit. :)
I think this is next step for ongoing experiments when you have instant charging caps on the grenade output...
Hi T1000
Thanks for bringing this again. Do you know anything more of his inverter? I have seen a drawing which presents a pulse train with intervals of lower frequency. His transformer is of 300T 0.75mm wire, and 50T secondary. I suspect that he tunes his secondary to the low frequency intervals as I have done this before while experimenting with D.Smith.
Jeg
Utopia Now
Hallo Ibrahim,
Quote"You have to learn how the electromagnetic waves are acting in a high frequency transformer system.
Regards.  Ibrahim.
It looks Wonderful,
Do you have the schematic  to the setup in the video  .. it is  good to have  "a" result  because from there on you can optimize  things ( results ) i guess.
Do you have scoop screen shots
You say : " You have to learn how the electromagnetic waves are acting in a high frequency transformer system."   What do you think should we specificaly look for  or  notice or take  care of   ... ?
Any way  Thanks Ibrahim    ... Amazing  :)
Utopia  Now
