0 Members and 46 Guests are viewing this topic.
AlienGrey
What is a phonon ?    https://en.wikipedia.org/wiki/Phonon
S9 if we are so ignorant, could you please explain what it is we need to ('lean') please ;) ?
Also while we are 'leaning' ;) how do you get a coil to resonate with multiple musical frequencies on in that close proximity ?
EXPLAIN  !
Also, who is going to market and buy a lawn mower that costs a few thousands of pounds ?
AG
magpwr
Quote from: lacphong on October 26, 2016, 05:22:50 PM
Hi mgpwr,
Good you see you back.  I'm wondering what's the size of your Nanocrystalline toroid?  I'm thinking about buying one of the 86mm or 95mm one, but from many of the pictures and videos you posted it look like it's the 136mm.  Very expensive!  LOL
Thanks,
LP
hi lacphong,
I took a quick measurement the inner diameter of my nanocrystalline toroid is around 10cm.Yes it is expensive item where efficiency is the "primary objective".
I may have forgotten to mention in the past the center tap using smaller toroid nanocrystalline(white plastic casing) is the one that lowers the presence of unwanted harmonics/ripples in output coil waveform besides the snubber.
Related to tesla coil circuit i have just completed designing a one of a kind  "prototype ultra high efficiency simple tela coil driver circuit" which produce to around 6.5kVpp at mere 20volts at 2Amps for around 110turns(resonance frequency~1.85Mhz test coil).
This result into 59volts per turn.Take note interrupter is not implemented yet which will lower 2Amps to around 1Amps depending on interrupter duty settings.
I able to go higher voltage like 30volts all the way to 150volts but interrupter is highly recomended.
Since this project  got no real commercial value in itself hence i am able to release this prototype circuit design in my youtube channel:sanjev21 within 48hours. :D
I am somewhat disappointed by all the existing tesla coil driver design as found in the internet.Either it's bad but really simple design or considered too complex for some for using pll or etc.
So look out for it and be amazed.
That's all for now.
citfta
S9,
Why don't you start your own thread to present your ideas?  Not only is it very rude to take over an existing thread, it also causes a lot of confusion for those trying to follow the original intent of the thread.  If your ideas are worth anything then they should have a separate thread.  Of course if you think they are so worthless you feel this is the only way for them to get any attention then I guess trying to take over another thread or two is what you feel you have to do.
magpwr
Quote from: Sequental.9 on October 27, 2016, 11:35:31 AM
Its not about musical fields Mr Gray its about the leading edge of physics in the search of the grand unified field ! The plank level is a very intense ocean of energy and is where all that is came from ! We also find holes in the fabric of space time when using phonon coils and we often observed energies and particles emitted through these holes only to return to where they came from and is an endless sea of potential.
My purpose is not to teach but offer up what is now used in many circles of research and bring these findings forward for all to consider for there projects !
But I fill its far to late to stop global warming with free energy alone ! The only other way is to pump large amounts of oxygen into the atmosphere ! And to do that we would need an electrolyser in the ocean as big as London ! Hydrogen will escape into space but oxygen is heavy and will dilate the carbon problem.
The Himalayan Plato is the priority as it keeps our weather system under control but the ice there is now 70% to 80% depleted ! We have only 20 years left to fix this problem or New York London and many other cites will go under water very fast ! Is that what you want ?
Keep attacking me and that is what you will get !!! LEAVE ME WELL ALONE !!! I come here as an open book of truth and its not easy to keep it all simple and step around stupid patents that stop progression !
If you just think about your self what does that mean for the rest of the world ? We have 20 years to turn this around so get on with it !!
S9
hi Sequental.9,
Why fear death if you know heaven is not easily accessible. :D
If you studied history long enough you will find that we humans do tend to make same mistakes over and over again.This is a hard fact in real life. :D
I do know parts of London will be flooded in the future as well as many other countries around the world.
Just accept it and move on for the better or the worst.Why bother pondering over and over.Just relax.
Climate change is irreversible as long as the human population keeps growing.
You are actually killing this topic although i don't really care.
AlienGrey
Mr Richardson, I'm not your enemy nor am i attacking you, and yet your quick to point out the folly in our greed as a species and yet appear to offer the same, but you give us little to work with I'm sure you can do better as this is not a sales rag or an online shop, its a means for exchanging helpful information that work or enable others to build from or on those ideas, Of course, you could start your own thread instead of taking over this one.
   'Where is the wisdom in your information' D S Eliot ?
A G
