0 Members and 367 Guests are viewing this topic.
NickZ
  It's possible that somehow T-1000 may be right. But, the how to go about it specifically, is not known or mentioned. Without the how to go about it, we are left with repeating speculations, only.
Tesla did not mention how to continually repeat the instantaneous lightning fast discharges. Or did he?
  So, how does this all relate to what Akula is doing, How specifically, or we'll be speculating until the cows come home, again. Or is that the idea...
T-1000
Quote from: verpies on May 22, 2013, 04:28:43 PM
Why?
Alas, when the switch S1 starts conducting, then the voltage across W1 is at maximum but current is at zero.
No interrupted current means no flyback pulse (...and even if there was a flyback pulse then it would be shorted out by R1 and the AC voltage source).
If you do same after W2 will have maximum voltage the released S1 on W2 shortly after short circuit will create BEMF in W2 which is usualy up 20-30 times higher than voltage before.
Quote from: NickZ on May 22, 2013, 05:27:28 PM
When you learn this method by doing actual testing the similarities will be more easy to spot in what circuits are doing. akula's self runner is not exception.
NickZ
  Well, I'm very much at it, how about you? No testing yet? How will you know if it really works, the way the you think that it does.
   Wesley is still stating that it all has to do with nuclear something, and looks like he's prepared for war, against an unknown enemy. But also does not test the idea, or at least show anything. Are metal powders and a glass tube that hard to get?
  I'd like to see you testing some of this, also.
verpies
Quote from: T-1000 on May 22, 2013, 05:28:58 PM
If you do same after W2 will have maximum voltage the released S1 on W2 shortly after short circuit will create BEMF in W2 which is usually up 20-30 times higher than voltage before.
Is this what you mean?
Can you draw the S2 waveform?
Note: Blue waveform is the current flowing in the power supply (it is not the current flowing in W1).
          Without R1 the power supply would explode when S1 closed (0Ω).
NickZ
Quote from: MenofFather on May 22, 2013, 02:16:49 PM
There hard to say or oposite or not, I think need just search frenquency then voltage of sine is most big. How say woman who build free energy generator, that from autogenerator need made sine on one coil and then with other coil, inductir leet say of few turns beet exatly with short impulses on sine most bigest amplitude, this makes big curent. So I now understand why need two frenquencies.
  I've been thinking of how akula may have done what you are mentioning above. Maybe he takes each end of the center tap coil, and adds two different voltages, and different current levels to each one of the two wire ends. So, that the there are several charges all going into the same wire, creating the big bang, which is then picked up by the 3 turn coil, and send to the capacitor and resonator coil. What do you think?
  Can you get a hold of the lady with the autogenerator, or not? Sounds interesting that a woman has done this.
  Thank you for keeping us posted on any news in the Russian forums, as well as anything on the Russian videos that may help us to understand, and to replicate the self runner device.
