0 Members and 124 Guests are viewing this topic.
Grumage
Quote from: AlienGrey on October 27, 2016, 01:57:16 PM
I agree but how do we stop it or police it, and won't he do the same on that one ?
It does look a bit like he is using the site to either disrupt it or publish his art work.
regards A||G
Dear  AlienGrey.
That's what a moderator does, a kind of policeman.
I have to agree with Carroll though, freedom of expression is very important and should not be stifled. Sequental.9 should start a new thread to expound his theories?
Kind regards, Graham.
dewetw
PM
PM
PM
PM
PM
I sent an important message via PM to those on this thread that is willing to stick to the topic and contribute.
You've got mail! Please go read it ;)
lacphong
Thank you for the info magpwr, I think I will buy the smaller one :)
Totally agree with you that, this project is more of a "prove of concept" educational purpose only.  It's very hard for anyone to get any commercial value from it...it's almost impossible to get a patent on any FE device, and it will extremely hard to convince people that the device even exist... :D
I'm planning to use a Class E Tesla coil, but looking forward to see your "one of a kind" Tesla coil design.  :)
Oh btw.  Are you setting up your device according to a diagram drew by Ibrahim?
Thanks,
LP
Quote from: magpwr on October 27, 2016, 09:45:23 AM
hi lacphong,
I took a quick measurement the inner diameter of my nanocrystalline toroid is around 10cm.Yes it is expensive item where efficiency is the "primary objective".
I may have forgotten to mention in the past the center tap using smaller toroid nanocrystalline(white plastic casing) is the one that lowers the presence of unwanted harmonics/ripples in output coil waveform besides the snubber.
Related to tesla coil circuit i have just completed designing a one of a kind  "prototype ultra high efficiency simple tela coil driver circuit" which produce to around 6.5kVpp at mere 20volts at 2Amps for around 110turns(resonance frequency~1.85Mhz test coil).
This result into 59volts per turn.Take note interrupter is not implemented yet which will lower 2Amps to around 1Amps depending on interrupter duty settings.
I able to go higher voltage like 30volts all the way to 150volts but interrupter is highly recomended.
Since this project  got no real commercial value in itself hence i am able to release this prototype circuit design in my youtube channel:sanjev21 within 48hours. :D
I am somewhat disappointed by all the existing tesla coil driver design as found in the internet.Either it's bad but really simple design or considered too complex for some for using pll or etc.
So look out for it and be amazed.
That's all for now.
magpwr
Quote from: lacphong on October 27, 2016, 10:15:00 PM
Thanks,
LP
hi lacphong,
I have already mentioned i am using only Akula circuit which is actually a not obvious parametric driver/oscillator which is using sub-harmonics of the resonances frequency.In a way L/C plays important role like adding more or less winding since it's harder to get exact capacitance value.
Just ignore URFA-ibrahim as well.I have achieve this feat before URFA even before i came know about parametric osillator.
In order achieve URFA effect(waste of time).
Let's say your L/c resonance is around 14.4khz from the 3 turns from the yoke.Your pwm generator would need to be running at twice the frequency at around 28.8khz.At this point you will hardly notice bulbs are lit at all.Then once you apply correct telsa frequency with the proper cut-off circuit.You are able to achieve his effect in no time.But like i said it's waste of time.
Many are made fools because of Akula older unstable design without using Earth.In that experiment base on obvervation and calculations Akula is actually using L/C resonance from the 3 turns.
But many fools did not know that the resonance frequency of the inner coil tesla/mini kapanadze like coil is actually "matematically few times"  higher than the resonance frequency of around 55khz from the 3 turns yoke. :D :D
That is Akula older device using lower frequency in order to get/drive higher frequency mathematically tuned at higher frequencies.
I have attached a old screenshot from Akula for your reference.
If you got a signal generator-sine wave then capture/frequency  a given frequency and then find out what is the right higher frequency for the smaller amplitude without altering the horz position in digital scope only.
I am very sure this earlier device is the one that made many look like fools eg:Ruslan along with many others likely thought that this was the way by using resonance all the way for this device. ;D
But do take note i am no longer here to teach but let others know that they are the fools in following Ruslan a prankster. :-X
Just ignore this delusional fool S9 whom i am very very sure got no electronics circuit designing.Just like the previous fool Atommix whom is able to generate composition in the megabyte. :D :D :D
Hoppy
Mags,
Good to see you back posting but please refrain from calling people fools just because you feel more knowledgeable in the 'art' than most others.
