0 Members and 118 Guests are viewing this topic.
conico
For those who are working to replicate Ruslan must establish steps for finding resonance frequencies.
I believe, I begin with the first step to determine which terminals from inductor coil and grenade coil are ground.
I powered circuit 'kasher' and I set the variable resistor to have current for 0.3-0.4 Amp to supply kasher and with  the oscilloscope tester near antenna to see the signal.
Then i used the second probe from oscilloscope for see the signal from grenade coil, it was 300-400 Vpp.  The signal from grenade coil must be in phase with antenna signal that means the ground from oscilloscope probe show me the ground of grenade coil .
The same for inductor coil.
If the signal from grenade coil is not in phase with antenna signal, I just change the terminals between them.
No matter kasher frequency, is only to determine which terminal from grenades and inductor coil is ground.
For me is the first step, let see the second?
Hoppy
Jeg
Quote from: boonk on October 28, 2016, 12:41:33 PM
for justawatt,
Thanks boonk ;)
Mercury came in to play now? Probably is full of phonons  ;D
AlienGrey
Quote from: Jeg on October 29, 2016, 04:45:03 AM
Thanks boonk ;)
It's confusing from a good few points as basically its just a parts list, and you have to remember the author was asking £5000 for the device and circuit, so for instance, where are the PDF's 1 - to - 6 ?
you also need the measurements of where to wind the various coils on the various tubes and how to set it up, and then there is the forum, anyone got a link to that, personly I would want knowledge or all that before I threw any money at any of it, ;)
A G
beboszek
Hi,
As wrote few days ago, I came back to experiments. I wound new coils (this time according to explanation of Sergiey in movie "VID 1 Обзор доски  FULL (AC)") and started with measuring some resonances on it. Maybe some of you remember the frequency his tesla was running. My first sweep of coil constructed revealed exactly the same freq. (clear dip in coil's impedance on 1.66M). But what is more interesting, such exact frequency is only for 19m grounding cable and proper ground in a garden. With regular house grounding freq is shifted ~100kHz as shown on attached pictures.
01.png -> wide spectrum
02_1660k.png -> narrower with 19m grounding
03_1750k_uziemienie_domowe.png -> narrower with normal mains grounding
Unfortunately while running around this frequency, I noticed no OU effects (so far).
Marek
