0 Members and 351 Guests are viewing this topic.
T-1000
Quote from: conico on October 29, 2016, 01:24:26 AM
For those who are working to replicate Ruslan must establish steps for finding resonance frequencies.
I believe, I begin with the first step to determine which terminals from inductor coil and grenade coil are ground.
I may point you into one of tuning directions from akula which was extensively discussed in private. In conversations with him I am trying to establish best simple way of tuning without use of very expensive instruments.
One of many ways is:
1) Disconnect push-pull. Short grenade output and leave it connected to the ground.
2) Attach current probe to the shorted grenade.
3) Run katcher with pulse trains (the power to the Tesla coil primary have to be cut as soon when amplitude on the secondary reach peaks).
4) Find maximum amps reading and see on which voltage and frequency it happen in Tesla coil. This will be the primary condition to look for.
5) Remove short and attach grenade output to the bulb. Now most complicated part will be the mixing.
6) You need to find the resonant frequency harmonics for the push-pull which will mix up and cause currents in the wire to flow in whirlwind fashion. It either may reduce power output or add-up. We are looking for adding them both for the power gain.
7) The currents from the Tesla coil on the grenade raise voltage on grenade due capacitive charging effect. So when you have push-pull causing 1A on grenade output and 1000V from the Tesla coil it may translate into 1kW charge on the output capacitors. This is where it was used elsewhere - Donald Smith device.
I attached modified D. Smith circuit for playground as well so it might help with reaching goals.
Cheers!
AlienGrey
The waveform is just a distorted sine wave. If  Some 'Regimental guy called 'Tom Beardon' repeatedly said you can get free energy if you don't destroy the 'dipole', why do you think he might have said that ? A sine wave does just that, destroys the dipole!
Afterthought! what do you think is meant by the dipole ?
regards  A G
AlienGrey
Quote from: T-1000 on October 29, 2016, 08:40:34 AM
Cheers!
That's an interesting circuit Arunus the neon driver circuit sets up the transfer frequency to the diodes and then 'does nothing as it's blocked by the 2 diodes ;)  but in saying that the transformer after charges up 'C' and once at it's firing voltage discharges into the rest of the circuit producing a huge 'spike' that would produce one hell of a flyback pulse like our relay video Nelson showed us >= free energy.
Doesn't it give you an idea whats wrong with Ruslans device Akulas too ?
regards  A G
NickZ
  Killing the dipole is caused by closing the system off, and then extra energy can't come into the system.
  Open systems don't kill the dipole.  Kacher circuit to the antenna is an open system. Using the Tesla idea of the third (open) coil.
AlienGrey
