0 Members and 507 Guests are viewing this topic.
AlienGrey
Quote from: verpies on October 30, 2016, 07:44:05 AM
But you are ;)
"Any sufficiently advanced technology is indistinguishable from magic."
Did Asimov or Clarke say that ?
Magic the technical term for it is T F M (total frickin magic) Dr Steven Greer (please don't send me a list of dead flys on him thank  ;).
Take 'that' I can remember taking me daughter to one of their pop concert a good while back now! ;)
the grenade coil, if you wind to the left you get 'amps' to the right you get 'volts', but if your not on it's wave length you get 'naff all!. Also the 3 turn coil, isn't that feedback ?
AG
verpies
Quote from: AlienGrey on October 30, 2016, 08:10:20 AM
the grenade coil, if you wind to the left you get 'amps' to the right you get 'volts', but if your not on it's wave length you get 'naff all!. Also the 3 turn coil, isn't that feed back ?
I don't know.  I don't understand why winding direction would make that difference.
NickZ
  I guess that just building a Kacher circuit like the one the Ruslan shown previously and now Adrian is using for his self runner is just to simple for some of you? Roma also used just a simple Kacher circuit for his device. You need or want something more complicated, for your Grenade-Tesla coil device, to start with, instead?
   Wesley:  Well, you did a good job of shooting down Thomas Bearden's ideas. He has a Phd, and is also a nuclear scientist.  Most of his ideas come from Tesla.  Especially for weapons production, and weather control. Where do your ideas come from?
Are you sure Tesla was wrong as well. Just because he also did not provide us with examples of proof of concept for self running devices.
  Wikipedia does not explain how to build a self running devices, nor how to build systems that run on the extraction of energy from the surrounding ambient.
  AG mentioned: "the grenade coil, if you wind to the left you get 'amps' to the right you get 'volts', but if your not on it's wave length you get 'naff all!. Also the 3 turn coil, isn't that feedback" ?
  It may not make a difference, it's done to cancel induction, at the node points, and that is why it is wound the other way at the nodes.
  The 3 turn induction circuit is not used for the feed back path. That is what the full bridge and PS are used for, looping back.
  It's also possible that "exciting electrons" has nothing to do with these devices.  However, It may have to do with ionizing the air, and the impact that that has on the surrounding ambient, instead. Then harvesting and drawing the created reversed impact back into the device, to be used for the load.
  Nelson was showing 0 amps, drawn, while running a load...  so we may have more to learn, still.
AlienGrey
Quote from: verpies on October 30, 2016, 08:13:38 AM
really ? because it's the rule when electrons excited. it's in the Don Smith video how to make it, I had better not post any more videos after the last one.
TheCell
Quote from: T-1000 on October 29, 2016, 08:40:34 AM
I may point you into one of tuning directions from akula which was extensively discussed in private. In conversations with him I am trying to establish best simple way of tuning without use of very expensive instruments.
One of many ways is:
1) Disconnect push-pull. Short grenade output and leave it connected to the ground.
2) Attach current probe to the shorted grenade.
3) Run katcher with pulse trains (the power to the Tesla coil primary have to be cut as soon when amplitude on the secondary reach peaks).
4) Find maximum amps reading and see on which voltage and frequency it happen in Tesla coil. This will be the primary condition to look for.
5) Remove short and attach grenade output to the bulb. Now most complicated part will be the mixing.
6) You need to find the resonant frequency harmonics for the push-pull which will mix up and cause currents in the wire to flow in whirlwind fashion. It either may reduce power output or add-up. We are looking for adding them both for the power gain.
7) The currents from the Tesla coil on the grenade raise voltage on grenade due capacitive charging effect. So when you have push-pull causing 1A on grenade output and 1000V from the Tesla coil it may translate into 1kW charge on the output capacitors. This is where it was used elsewhere - Donald Smith device.
I attached modified D. Smith circuit for playground as well so it might help with reaching goals.
Cheers!
Hello T-1000
since I have build a kacher , which was working for a short time , because the transistor burned out frequently; there is still a tube with a thin HV-
winding lying around, and for that reason perhabs I give it a try.
->3) you use a voltage devider on the secondary on the tesla-coil to monitor the at the peak cutted sine-wave?
->4) how to detect maximum amps in grenade ? clamp meter (most likely not because of the frequency) better an 1ohm resistor and monitoring the
voltage of that on the scope too.
For this testcase a function generator is needed with a a max frequency at least 20Mhz.Or what other circuit would you chose?
Cutting off at peak of the sinewave will be achieved by chosing the right ts /t (switch on duration) ?! and this is all done manually.
After determining the frequency , most likely when attaching the kacher circuit the tesla coil will not resonate at this frequency so it will be adjusted
by cutting off the thick wire of the antenna?
Please comment/correct these steps ;  Thanks a lot.
