0 Members and 125 Guests are viewing this topic.
NickZ
  0.1A to 10amps???
  https://www.youtube.com/watch?v=o3vvv2JBNQA
   Where do the extra amps come from? Even if the amp meters are not reading properly.
So, do we really need amps to produce amps. OR not?
Hoppy
Quote from: NickZ on October 30, 2016, 10:08:33 AM
  0.1A to 10amps???
Even if the meters are reading properly, why should there be extra amps. What about the input and output volts (ref ohms law).
NickZ
  Why should there be "extra amps"? Because the light bulbs are lighting, and 0.1A won't produce that result. Or will it?
  Not sure about your question, though. There may be more to it than just input to output volts readings.
  Maybe if you rephrase your question.
T-1000
Quote from: TheCell on October 30, 2016, 08:27:04 AM
Hello T-1000
since I have build a kacher , which was working for a short time , because the transistor burned out frequently; there is still a tube with a thin HV-
winding lying around, and for that reason perhabs I give it a try.
->3) you use a voltage devider on the secondary on the tesla-coil to monitor the at the peak cutted sine-wave?
->4) how to detect maximum amps in grenade ? clamp meter (most likely not because of the frequency) better an 1ohm resistor and monitoring the
voltage of that on the scope too.
For this testcase a function generator is needed with a a max frequency at least 20Mhz.Or what other circuit would you chose?
Cutting off at peak of the sinewave will be achieved by chosing the right ts /t (switch on duration) ?! and this is all done manually.
After determining the frequency , most likely when attaching the kacher circuit the tesla coil will not resonate at this frequency so it will be adjusted
by cutting off the thick wire of the antenna?
Please comment/correct these steps ;  Thanks a lot.
Hi,
For the Tesla coil driver I am in progress on playing with akula katcher:
http://imgur.com/a/6Bevd
For finding when Tesla coil is reaching its peak the scope probe placed nearby can show it. Usually I place it shorted with its ground wire to ensure it survives HV EM field. Then arranging number of katcher pulses on the pot resistors before it starts consuming too much amps on the primary. The function of the Tesla coil + choke between top load ("antenna") is simulating high power nanosecond pulse generator.
For determining max amps the current sense with the scope is the best option. The clamp meters will lie all the time due high frequency and high tension field around Tesla coil. The shorted and grounded grenade coil with current sense on it shows best result.
Cheers!
Hoppy
Quote from: NickZ on October 30, 2016, 10:46:59 AM
Its unlikely that 0.1A from the grid could produce the result shown but how reliable are the readings (see T1000 comment above)?? The voltmeter reading across the bulbs is all over the place and yet both input and output current readings appear stable. Nothing of much value can be deduced from this video to determine whether this device is running OU.
