0 Members and 119 Guests are viewing this topic.
GeoFusion
Hi :)
Ok, let me start....
Hoppy, (all)
I have already shown it Operating with 2x 12Vdc (24V) car batteries and  the effect is still there.
Even when one of the batteries are failing ( starts to give fluffy charge and depletes fast), you can see reduction on output.
There is no difference while working with PSU connected to mains in comparison with batteries about the ground.
This is already shown that there is no mains coming in from ground to this device.
Device is dependent on ions!
One thing I can say is, to get that spot where it manifests for the load, can be so fragile.
There are better tuning spots where there is better output than what I have shown.
but the moment you have bemf merged, it is explosive energy, short the wire it and will burn wires of smaller gauge.
https://www.youtube.com/watch?v=1OSpeWlR2Qg
What is missing now is Interrupter to make it work better and how it should be done.
Adrian Guska, which is using it and has done it properly recently.
But If you request me to disconnect push-pull while in full swing, sure. no problem,
I have completely nothing to hide, it's in plain sight :)
it would turn out to be the same as when I disconnect kacher circuit from play.
You will hear absolutely nothing,  it would look like the system just died.
Also, that the glare of the bulbs is just slightly a bit over exposed but not to much
but the bulb is bright enough it can hurt your eyes if you stare at it to long, or any other low wattage bulbs.
the PSU was also drivin one time from a UPS power bank. Same results.
The system eats 4-5 amps which I currently have on bench when on correct tuning spot,
when tuning it right to have gain.
There is also another tuning spot where I read about 9 amps in, and very very low lumins on output.
Differences are extreme sometimes.
when doing it all with my PicoScope on laptop that is my oscilloscope.
But to be honest, Synchronization happens how you connect it correctly.
But getting  the Sweet spot for effect is really to be using a scope knowing Fall time and up.
There is one more thing I could share, I have even shown it I guess in earlier recordings.
By adding load ( bulbs ) you can clearly see there is no more intake of amps at input when in full swing.
but there comes a moment where you reach boundary where bulbs starting to go Dim while adding more.
then you know you passed over the Threshold for good loading.
When that occurs you can see when adding more load , the input amps also drop with it.
  Nick,
By using the spectrum analyzer it might give you that reading which it can pick up
but push-pull is ringing on 23-24Khz other spot is 27khz on scope.
Placing my hand around the device sometimes can *Raise output lower amps input* or* Lower output and increase input*.
It all depends on the tuning you have programmed it to be.
You see how I place my hand over the device right? Well, it's always a different spot when tuning it.
sometimes all the way to the right or above the device or in front, or in the back of it.
It's the field which I'm interacting with is not collecting all the Ions, is what my hand is disturbing.
It has odd characteristics..was all for the learning process, but for what I know now is that I still have to tweak certain parts
for it not to be so fragile with moving object which is grounded  near it.
Collapsing field or vibrating field is necessary.
Yoke will eventually get warm when it's working properly, be reminded it also gets back spikes and have to handle the pressure.
even when you have warmth on the grenade being generated is sign of production.
Average temp measured was 45-48 degrees celsius, can reach about 50 degrees. on 6th layer grenade within about 10 min run measured with
laser thermometer.
There is still bit more to do and experiment on, I am close but needs very small tweaks still.
Cheerz~
verpies
Quote from: GeoFusion on October 31, 2016, 11:47:08 AM
Are you able to tune it even when the "mediator" transformer is positioned far away from the grenade coil ?
GeoFusion
Quote from: verpies on October 31, 2016, 11:58:33 AM
Are you able to tune it even when the mediator transformer is positioned far away from the grenade coil ?
Hi Verpies,
Yes I did try,
I have placed the mediator yoke about like 1 meter or more away to see if it does any difference .. but
still the same results. that field is because of Tesla coil influence. nothing els.
You know.. when having the system operating completely, you can hear the mediator yoke and the Push-pull yoke
having the same frequency. ;)
*Edit
You can also hear like cracking noices within mediator, just like vibrations.
when it's working properly with nice loading
verpies
Quote from: GeoFusion on October 31, 2016, 12:30:26 PM
You can also hear like cracking noices within mediator, just like vibrations, when it's working properly with nice loading
Can you feel these vibrations with your hand or just ears?
Hoppy
Geo,
Thanks for your comments which I appreciate.
Its clear that the tuning of the system is highly sensitive to hand capacitance and component placement. The disconnection of the earth wire on both a mains and battery driven system is considerably changing the impedance of the tuned circuit, resulting in an impedance mismatch to the load. The connection of the earth wire is not sucking-in energy from the ground, just improving the impedance match from the grenade to the lamp. I'm satisfied that you have replicated the effects seen on other videos and hope that you progress to a self-runner.
