0 Members and 124 Guests are viewing this topic.
Ed morbus
I've been on vacation
Does anyone have a link for last circuit diagram
AlienGrey
How long did you go?  I don't think much has changed,  a lot of the Russian stuff is turning out to be misleading, who knows the truth ? try this one ;)
Jeg
@Verpies
Attached is a HS N-channel mosfet driver. What i would like is to utilize the negative peak at mosfet's drain and charge with it some caps. My question is if C1 will absorb some of the negative peak's energy, as this is something that i don't want to. If you think so, then i should move to LS P-channel. What is your opinion?
ps. AG, is that a pirate map??? ;D
Ed morbus
NickZ
   I have had some problems when connecting my Kacher circuit and full bridge rectifier to the the 28t coil. This is to provide the input to the Kacher circuit with input power to run with.
  The problem is that there is too much power going into the Kacher circuit, and it causes overheating on the Kacher circuit transistor, and other components.  So, How can I lower the output from the 28t coil to the full bridge/Kacher circuit, so that I get only 24v output from the full bridge to the Kacher's input.  My 10k pot and 2000k worth of resistors on my Kacher circuit is not enough to lower the voltage. I also have placed two chokes on it as well.
   Any ideas?
