0 Members and 119 Guests are viewing this topic.
conico
Did you try the duty cycle lower then 17% ?
You must have a coil sock in katcher diagram , I believe that must have more then 100uH for each part.
if you change your sock coil the frequency of katcher will change.
In my Katcher  I supply it at 24v an I have a sock coil at 100uH each part and the power of Tesla coil was low. I change it with a sock of 48 uH each part, a permissive one and my tesla coil is very powerful, 6-8 mm spark with the screwdriver.
Jeg
Quote from: NickZ on November 01, 2016, 10:58:56 AM
   I have had some problems when connecting my Kacher circuit and full bridge rectifier to the the 28t coil. This is to provide the input to the Kacher circuit with input power to run with.
  The problem is that there is too much power going into the Kacher circuit, and it causes overheating on the Kacher circuit transistor, and other components.  So, How can I lower the output from the 28t coil to the full bridge/Kacher circuit, so that I get only 24v output from the full bridge to the Kacher's input.  My 10k pot and 2000k worth of resistors on my Kacher circuit is not enough to lower the voltage. I also have placed two chokes on it as well.
   Any ideas?
Hi Nick
It is supposed that all this high voltage out of the 28T sec, is applied briefly to your katcher driver through a thin sync pulse. If you continuously run your katcher by that voltage you will damage it of course. To do what you want, for me it is better to decrease your Secondary's turns. But is there any point for that? You already have 24V out of your pwr supply.
NickZ
   It's just a simple Kacher circuit, conico, without a duty cycle controller.
I'm just trying to keep the input volts from going too high to it.
   Geo: Can you explain a bit more about the "interuptor" transistor, and how to incorporate it into the Kacher circuit?
   I know that you haven't tried to do it, yet, but, any info on it would be appreciated. You can PM me if you like, I also use whatsapp, and Skype.  I've called T a couple of times, but he has not responded, yet.
   I also used a "tone generator" and I can't hear the frequencies of 25Khz to 27kHz. But, I can hear yours, and it's the same as the tone generator running a tone of 6.98kHz.  So, I'm still interested in finding the differences. A current pic of the scope shot, would do.  BTW: do you have a scope, or can borrow one?  If not,  don't worry about it.  It's just a curiosity of mine.
As I'd like to run at a similar frequency, of both grenade and Kacher circuits for comparisons to yours, and to apecore, also. As we have similar somewhat similar set ups of the Kacher/grenade coils system.
  Yes, I know about the TL494, and will go that route, in the future, no need to convince me, I'm already aware of what it can do. However, so far,  I've been able to replicate most of the same "effect" that you are showing up to now, even without it.
  The feed back path is now the tricky part, as well, which is also what I'm dealing with, in the simplest way possible.
For me, simple is what I'm looking for.  Hopefully with commercial controllers that will do the trick, instead of homemade.
T-1000
Quote from: NickZ on November 01, 2016, 11:30:53 AM
   I know that you haven't tried to yet, but, any info on it would be appreciated. You can PM me if you like, I also use whatsapp, and Skype.  I've called T a couple of times, but he has not responded, yet.
In akula's katcher http://imgur.com/a/6Bevd the transistors Q2 and Q3 are doing this. The output of that goes to the katcher transistor.
In regards to Skype, I still did not see your contact request...
AlienGrey
Quote from: T-1000 on November 01, 2016, 11:37:21 AM
don't mind me but the katcher to me is the Tesler coil or in our model the relay coil turning on and off exciting the electrons, now is it Flemings right-hand rule or his left one is the motor and the other the generator. Any one got any thoughts on that ? so what about the TL494 driving the two grenade coils 38 m and 19m anyone know what they are doing? Oh and don't forget the Tesla coil is assumed to be about 10 times the grenade resonant pass frequency.
A G
