0 Members and 232 Guests are viewing this topic.
lost_bro
Quote from: T-1000 on November 01, 2016, 11:37:21 AM
In akula's katcher http://imgur.com/a/6Bevd the transistors Q2 and Q3 are doing this. The output of that goes to the katcher transistor.
In regards to Skype, I still did not see your contact request...
Good Day T-1000
Quick question:
Is this not redundant, (Akula Q2, Q3 transistors etc.) when using the Oleg/Ruslan/Sergie variable pulse width packet generator circuit that was discussed  a year or so ago?  It looks to me that the Oleg/Ruslan/Sergie or modified variation of it will offer superior control considering that the packet generation width and phase timing is totally adjustable.......
take care,peace
lost_bro
Hoppy
Quote from: NickZ on November 01, 2016, 12:32:12 PM
   What I've seen in most all the homemade push pull TL494 controller boards, is that the output at the bulbs is reduced and limited to about 120w, or so.  From the 24v, 5A, draw from a PS or batteries, such as what Geo is showing.
   I don't know what my induction circuits is drawing, as the idea is to make it self run, regardless, even without limiting controllers.
Watch the very beginning where he shows a 1A reading. That is what his push-pull is drawing before the Kacher is switched-on. Does his Kacher pull the other 4A or is this shared by the push-pull?
C'mon Nick. By now you should know what your push-pull is drawing, as you have both a meter and a scope. If Geo can do it, so can you!
Hoppy
Quote from: lost_bro on November 01, 2016, 01:56:37 PM
Good Day T-1000
Quick question:
take care,peace
lost_bro
Please resize your image.
conico
Quote from: NickZ on November 01, 2016, 01:17:18 PM
   T:  Adrian's Kacher is showing no signs of having PWM controller and pulse timing. So, how is he doing it with just a transistor?
Or is he?   Is there any schematic or diagram of his set up showing his Kacher circuit posted yet?
   Does anyone have the photos of Adrian's system?  I saw some very clear pictures of his system posted here a while back and I'd be interested in downloading them, if possible.
Yes, NickZ, look that movie:
https://www.youtube.com/watch?v=_0GGu_j7WTw&feature=youtu.be
apecore
Hi All,
Nick,
As the picture shows,... printboard left TL494 and TC4420 pushpull drivers and right the mentioned schematic Akula 0083 wich T-1000 also posted.
The scope shot is from the grenade output,..  btw it is all hooked up as the Akula0083 schematic, only my kacher primary is still connected to the 24Volts.
Also i rewind my primairy 2 x 12 turns on the yoke in a bifilar way,.......... this cleans the drain pulses in a very positive way,....  i don't have snubbers installed only draining it in a cap wich is being fed back in the main battery.
I have one problem,.....  I can't get the kacher interuptor puls on the left side of the sinewave top?
Somebody some suggestions?
Also no significant OU till now,....  unless tryed many things and all kinds of tuning.
I want to address because we are still discussing about the reason the "effect" is appearing.
As Hoppy several times pointed out it does mainly appear by the HF interference on the gates of the Push pull fets.
I have rebuild my push pull (shortned wire's etc.) and my gate signal is clean even with kachter continuesly running.
And as a result i ve not been able to get the Geo "Effect"again.
So small rap up about my progress.
If someone has a idea how to move the kacher spikes,...  your welcome.
Cheers
