0 Members and 232 Guests are viewing this topic.
conico
''Hero Member
View Profile  Personal Message (Offline)
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #15519 on: October 30, 2016, 01:13:38 PM »
Quote from: AlienGrey on October 30, 2016, 01:10:20 PM
the grenade coil, if you wind to the left you get 'amps' to the right you get 'volts', but if your not on it's wave length you get 'naff all!. Also the 3 turn coil, isn't that feed back ?
I don't know.  I don't understand why winding direction would make that difference.''
I'll try to answer :Way we use coils wound in maner cw ccw?
If we have a coil like grenade coil, half cw and half ccw and a signal at resonance , we can see is 50 times more voltage on each part matched with the total coil.
This is from Mr. Utkin's documents PDF, it was post years ago .
AlienGrey
I think we have just drifted off a bit, I  think we have to spike the Katcher tesla coil with a pulse on and off at the exact time and phase look at the original akuls circuit the 74hc14 drives the |Katcher control circuit on the bottom right of Akula's original circuit that part of the electronics has full trigger and control of the switching .
A G
lacphong
Hi magpwr,
Thank you for all the hints...  :)
Man you got me all confused now, I thought URFA-ibrahim is the way to go...  :-\
Anyway, if I'm not mistaken, the video where you took the screenshot from, Akula was showing how to find the resonance frequency of the coil, then using a spectrum analyzer to find the harmonics frequency of it, which is the 3rd harmonics.  Then he showed that when the frequencies are harmonic of each other, they will line up like seen on the scope.  Am I correct?  Now the question is; which harmonics should I use, and does it matter?  I see a lot of talking about 3rd, 60th and 63rd so far.
Here is what I'm planning to do:
1.  Find the resonance frequency of the grenade coil, let assume it's 55kHz.
2.  Then I have to set push-pull, and the 3 turns + .47uf cap to resonate at 3rd harmonics below 55kHz, which is 18.33kHz.
3.  The resonance frequency then would need to be at the 60th or 63rd harmonics of the 18.33kHz.
Am I missing anything here magpwr?
Thanks much in advance.
LP
Quote from: magpwr on October 27, 2016, 11:00:36 PM
hi lacphong,
I have already mentioned i am using only Akula circuit which is actually a not obvious parametric driver/oscillator which is using sub-harmonics of the resonances frequency.In a way L/C plays important role like adding more or less winding since it's harder to get exact capacitance value.
Just ignore URFA-ibrahim as well.I have achieve this feat before URFA even before i came know about parametric osillator.
In order achieve URFA effect(waste of time).
Let's say your L/c resonance is around 14.4khz from the 3 turns from the yoke.Your pwm generator would need to be running at twice the frequency at around 28.8khz.At this point you will hardly notice bulbs are lit at all.Then once you apply correct telsa frequency with the proper cut-off circuit.You are able to achieve his effect in no time.But like i said it's waste of time.
Many are made fools because of Akula older unstable design without using Earth.In that experiment base on obvervation and calculations Akula is actually using L/C resonance from the 3 turns.
But many fools did not know that the resonance frequency of the inner coil tesla/mini kapanadze like coil is actually "matematically few times"  higher than the resonance frequency of around 55khz from the 3 turns yoke. :D :D
That is Akula older device using lower frequency in order to get/drive higher frequency mathematically tuned at higher frequencies.
I have attached a old screenshot from Akula for your reference.
If you got a signal generator-sine wave then capture/frequency  a given frequency and then find out what is the right higher frequency for the smaller amplitude without altering the horz position in digital scope only.
I am very sure this earlier device is the one that made many look like fools eg:Ruslan along with many others likely thought that this was the way by using resonance all the way for this device. ;D
But do take note i am no longer here to teach but let others know that they are the fools in following Ruslan a prankster. :-X
Just ignore this delusional fool S9 whom i am very very sure got no electronics circuit designing.Just like the previous fool Atommix whom is able to generate composition in the megabyte. :D :D :D
AlienGrey
Quote from: conico on November 01, 2016, 02:38:48 PM
''Hero Member
It's Flemings Left-hand and right-hand rule depending on if it's a generator or a motor. and exciting the electrons.one way you get amps the other voltage. it's all basic stuff.
conico
for apecore,
TC4420 is non inverting driver, you don't have a ''signal --the driver start later'' in left part of sinusoidal signal
Itsu have the same problem with ucc non-inverting, he makes a movie with that problem.
Maybe you must use an inverting driver TC4429
