0 Members and 92 Guests are viewing this topic.
T-1000
Quote from: itsu on May 23, 2013, 06:53:14 AM
I guess T-1000 means something like this;
Regards Itsu
Editted:  changed diagram.
Youp, that fits concept for seeing what is happening after shorting on peaks. Ismael did capacitor disconnect from source after pulse then unloaded it into motor (which makes explosive discharge) then reconnected back for second pulse.
I think this is simplest approach what you can have before going to play with coils and injecting HV into this circuit. When you will have test results there will be more understanding in what I posted here from http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/975/
Cap-Z-ro
I don't know if its that I am getting better at absorbing concepts or if Ismael just has a way of making things more clear in my mind...but I've now reached the stage where I can now start trying things.
Finally
Regards...
NickZ
  Akula is already using a 12v to 220v 400watt commercial DC to AC inverter, then possibly rectifying AC back to Dc, and sending that to his homemade circuit board. That small circuit is being used as a driver for the yoke circuit.  There is a single iron core toroid on the small bread board with only one winding on it, two trim pots, for adjusting voltage, and possibly also the frequency, some caps and Fets, and a single Led indicator light, among other things. So, it's an adjustable pulse circuit.
  To me the magic may lie in just what that pulse circuit does with the yoke's primary 12 and 12 turn center tapped coil. I also feel that the yoke must receive some kind of high voltage and current, otherwise there would be close to nothing at the output end of the 3 turn coil. We could probably figure out just how much voltage and current it would take for the yokes 3 turn coil to output only 50 volts, but the current output is still unknown.
  Lets just for now say, that this pulse circuit is possibly what may account for the anomaly found in the rest of the circuit, which to me the rest of the circuit is too simple to be of much importance, in the cause of this  unknown effect. Although the air coil's inner choke circuit, may or may not be needed, at all.
In anycase, the choke being just a coil and cap, is NOT how Hendershot had his inner choke circuit set up, as it was also connected by wires, to an outside transformer, also.
  Just some thoughts to toss around...
truesearch
@Cap-Z-ro:
If you have ideas and going to do experiments based on Ismael's work, please start a thread and share your progress  :D
truesearch
anandml
Quote from: NickZ on May 23, 2013, 11:15:29 AM
Nickz
This is my assumption circuit. Please refer this circuit diagram. I have doubt about L4 winding connection..Check this and make some correction....
