0 Members and 37 Guests are viewing this topic.
AlienGrey
AlienGrey
Quote from: conico on November 03, 2016, 11:54:58 AM
That way my device is not working. I have a wrong diagram of grenade coil and inductor . I realised this when i have a lot of voltage on antenna and just 50-100v on Grenade coil.
  I suggest that everyone who works replica Ruslan to check them as you wound coils.
if you have less voltage then do you have more amps available ? Isn't it the way the grenade coil is wound that trades of amps for volts ? ie Flemings Left  and His Right hand rule ?
AG
conico
No, more voltage will be more amps ,less voltage mins less amps, Ohm's law.
AlienGrey
Quote from: Hoppy on November 03, 2016, 11:29:28 AM
Thanks Alien. You don't need the PSU earth wire connected to get a good bang on the cap. The neutral is good enough.  ;)
it does it with a 12v battery too.
AlienGrey
Quote from: conico on November 03, 2016, 12:15:32 PM
The  grenade I have been doing tests on is 10m cw then 10m ccw, then 5m cw then 5m ccw then 2.5m cw then 2.5m ccw. , all on a 50mm drain pipe does that help ?
