0 Members and 42 Guests are viewing this topic.
MenofFather
Quote from: anandml on May 23, 2013, 12:24:43 PM
Nickz
This is my assumption circuit. Please refer this circuit diagram. I have doubt about L4 winding connection..Check this and make some correction....
There some incorects. Здесь явные ошибки. He say and show that white wire one end go to lamps, other end go to graund, minus of electronics and to lamps. And say that 220 volts go to keys, keys he means mosfets.
Grumage
Evening All.
Has it occured to anyone that this coil shorting method could be the source of the "mystery" noise in TK's devices? Apparently if this method is used at higher frequencies an even better output is achieved.
So to practicallity... How can we "crowbar" this transformer at the right moment in time. As Ismael has noted the internal resistance of any semiconductor is not ideal so he placed many in shunt mode to reduce the overall resistance. Obviously mechanical shorting could be used but this also would have difficulties in synchronisation with the waveform. But I am sure I have read elsewhere that TK used "Car points" in one of his devices??
So, an open question to all the electronics buff's. Who can design a circuit??
Cheers Grum.
MenofFather
I draw only one mosfet to easy draw and understand. I think possible make and with one mosfet probrally. There punctire capasitor I not shore or it needed but think probarly needed. Duty cycle going to mosfet about 1-40 precents I think.
verpies
Quote from: T-1000 on May 23, 2013, 09:50:01 AM
Youp, that fits concept for seeing what is happening after shorting on peaks.
On which peaks shown on this diagram (red, blue, pink), should the secondary be shorted by the switch S2 ?
Hoppy
Quote from: Grumage on May 23, 2013, 12:53:36 PM
Evening All.
Cheers Grum.
Evening Grum,
It has been suggested to me that the mystery noise could have been as a result of two seprarate 50Hz supplies (one from the grid and another from an inverter being combined into a transformer. The inverter output into the primary and the grid supply into the secondary. At certain times at switch-on, the supplies will be sufficiently out of phase as to cause the noise. I have thought carefully about this and this fits how I think the 'Green Box' device is constructed.
