0 Members and 81 Guests are viewing this topic.
Hoppy
Quote from: GeoFusion on November 04, 2016, 06:45:10 PM
Hoppy,
Btw, about letting one mosfet drive the system, If I do that, it wont get me to where I need to reach
Necessary drive of two is needed here, Tuning will be completely different if having only 1 fet driving.
It might also not make it possible for me to resonate to where I need to.
Cheerz~ ;D
Geo,
I'm certainly not suggesting that one mosfet should be disabled deliberately, just that this may be happening during operation, as explained by Bat1Robin2. Anyway thanks for posting your second video. I look forward to seeing your scope shots and measurements in part 3.
Hoppy
Quote from: PolaczekCebulaczek on November 04, 2016, 09:37:02 PM
I have read on some russian forums that all of this devices (ruslan, akula, andrian) have one flaw (apart from being geodepedent) that is, after some time they would stop working and need to be retuned, it seems that power from ionosphere(the source) frequency is changing overtime, huh.
Hoppy
Quote from: NickZ on November 04, 2016, 07:37:08 PM
   My yoke core does not ring, nor does it make observable interference noises , nor is affected by lifting it up off of the table, and moving it around while it is running.  The distance from the outside of grenade coil to the center of my yoke coil is 7 1/4 inches.
  Of course there is an effect from the nearby Kacher, to the grenade coils. As well as to ones body, and hands moving around the device,  but not in a positive way on my device.  I can't raise the output by placing my hand on the antenna, or near it, that just diminishes the output, instead, interfering with the tuning, but does not improving the output at the bulbs.
Nick,
Have you tried interconnecting as per Geo's v3 circuit? It may not be possible for you to achieve the same level of 'effect' as Geo demonstrates, as you are not using a PWM push-pull. Bat1Robin2 has explained what is causing the 'effect' when using a PWM push-pull. I think Geo's 'effect' using his v3 circuit is likely being enhanced by his earth wire throwing his series resonant circuit out of resonance. I would like to see Geo using a lower wattage lamp, say 60W or 100W in place of the 300W in his next measurements demo.
Unless you are prepared to take that extra step and use a PWM push-pull as Geo is urging you to do, neither Bat1Robin2 or anyone else is going to really convince you  that you are wrong when you say that - "These are not conventional devices, nor are they closed circuits, and have little to do with normal conventional system operations" - by explaining or showing you evidence of the cause of the 'effect'. You will need to do these measurements on your bench using your instruments and device to prove the cause of the effect to yourself. Doing this will improve both your knowledge and skills in electronics. I've got far too much work on my bench to even attempt to get back experimenting with this device.
Tomtech29
Quote from: Hoppy on November 05, 2016, 05:28:33 AM
Nick,
Have you tried interconnecting as per Geo's v3 circuit? It may not be possible for you to achieve the same level of 'effect' as Geo demonstrates, as you are not using a PWM push-pull. Bat1Robin2 has explained what is causing the 'effect' when using a PWM push-pull. I think Geo's effect using his v3 circuit is likely being enhanced by his earth wire throwing his series resonant circuit out of resonance. I would like to see Geo using a lower wattage lamp, say 60W or 100W in place of the 300W in his next measurements demo.
Unless you are prepared to take that extra step and use a PWM push-pull as Geo is urging you to do, neither Bat1Robin2 or anyone else is going to really convince you by explaining or showing you evidence of the cause of the 'effect'. You will need to do these measurements on your bench using your instruments and device to prove the cause of the effect to yourself. Doing this will improve both your knowledge and skills in electronics. I've got far too much work on my bench to even attempt to get back experimenting with this device.
Hi.
I am convinced that is not otherwise in a situation Geo described with the above-mentioned effect by:
Bat1Robin2.
- Geo, We look forward to the scope of the gates of transistors and capacitor winding 3 LC.
I've seen what happens when a hand is applied to the heat sink transistor :D
and now you know what happens when you connect GND of the courts oscilloscope to drain.... (If I'm right I will not effect) :D
do not quite understand what's going on in this coil is not she wound differently:
https://www.youtube.com/watch?v=poC07RRRCfo&t=21s
itsu
Quote from: NickZ on November 04, 2016, 06:18:49 PM
  Itsu:
  Good to see that you are still with us, at least in spirit.
   I don't know if you've seen my last video, lighting up 400 watt bulbs, and showing the amplification effect, which does brighten up the bulbs, more so than just what the induction circuit can do by itself.
https://www.youtube.com/watch?v=Yr25PT2iM9o
   I've also had some problems with my Kacher getting too hot from too much voltage/current , as it's connected to the 28t coil through a full bridge rectifier/capacitor and then to the Kacher's input.  I need to reduce the input to the Kacher circuit.
  Any ideas?
   Well, I've since then lost the "amplification effect", and I'm still trying to get it back. Not easy to do...  as now I have absolutely no added extra power, when connecting up the Kacher circuit to the induction circuits, and the bulbs remain the same.
As did yours.
   Once I figure out just what causes the "amplification effect", exactly,  I'll let everyone know. For now I believe it is the way the device is connected up, as the most important point. Even more so than frequency matching, impedance, sync,  etz... or even the ground.
   Geo lit his device bulbs using the negative (or positive) of an old dead car battery, as well.  So...
   How about taking your device outside for a test run, and connecting to an earth ground???  Or car battery negative.
   We would like to see you back in the game.
   Roma, did not use nor need an earth ground to obtain 4000 watt output.
Nick,
yes, i have seen your video's as like you said, i am still with you guys.
Its hard to judge your video's for potential overunity, those bulbs look bright, but are they really?
Concerning your Kacher, if it is powered from the 28 turns secondary and that secondary is not used for anything else, i would simply
unwind some of the 28 turns (like go to 20 turns) rectify that and see if the lowered voltage is enough for the kacher to be stable now.
For the "amplification effect",  as Geo showed, grounding is important, perhaps check on your ground, if it still is firmly connected and/or no corrosion has
formed on your ground rod etc.
I was thinking of moving with the Ruslan setup to a seperate room downstairs away from my equipment and with a seperate ground, perhaps i will do that some day.....
Thanks,   regards Itsu
