AlienGrey
Quote from: NickZ on November 05, 2016, 10:25:21 AM
NOT OU! As not one person has overunity, nor will ever show "more out than in". No use wasting time trying to look for it, in that way. Hoppy. The effect that I am showing is the same as Geo's, even without the PWM. I just don't have all the noise and interference, due to his long stray wires like Geo has on his device. Nor do I think that your evaluation is correct, nor Bat1Robin2.  I doubt that Akula, Oleg, Adrian, Ruslan, Roma, and other's that have achieved self running would agree with you, as well.
   IF the device self runs it will be obtaining the energy from "somewhere" as it's input source. That is what we need to look into and study, just how to best tap that source for the highest gain.
Can I ask how you run your KacherTRANSMITON coil is it fee running or not, and if not how is it locked to the desired frequency and what's the band pass frequency of 'your' grenade coil  out of interest ? ?
AG
itsu
Quote from: beboszek on October 29, 2016, 07:12:25 AM
Hi,
As wrote few days ago, I came back to experiments. I wound new coils (this time according to explanation of Sergiey in movie "VID 1 Обзор доски  FULL (AC)") and started with measuring some resonances on it. Maybe some of you remember the frequency his tesla was running. My first sweep of coil constructed revealed exactly the same freq. (clear dip in coil's impedance on 1.66M). But what is more interesting, such exact frequency is only for 19m grounding cable and proper ground in a garden. With regular house grounding freq is shifted ~100kHz as shown on attached pictures.
01.png -> wide spectrum
02_1660k.png -> narrower with 19m grounding
03_1750k_uziemienie_domowe.png -> narrower with normal mains grounding
Unfortunately while running around this frequency, I noticed no OU effects (so far).
Marek
Hi Beboszek,
Sorry for the late reply.
Nice screenshots in that post, which are from your Grenade i understand.
Are they with the inductor installed?  And if so, what was connected to this inductor (open, 470nF cap or?)?
I think that your Spectrum Analizer and/or your FG are always connected to your house grounding, so the black leads of those instruments are always house grounded.
How would you measure the coil (grenade?) with the ground in the garden only, did you remove the instruments house ground?
I used my DSA815 to characterize my Grenade in a similar way you did i guess (100KHz to 10MHz), see the screenshot below.
The inductor was open, when attaching a 470nF cap to the inductor, things change off course.
Regards Itsu
conico
For NickZ
I had the same problem, too much power at 24V powered Katcher
I made myself choke, the first two were burned insulation, the third choke was too high inductance and low power for Katcher
The fourth choke is close to what I wanted, I can adjust the variable resistor amperage of between 0.3 and 3,6A.
I think the best Choke inductance is 80-100uH for each side  for 24v supply.
NickZ
   conico:
   Thank you very much for your reply to our problems with the over voltage/current going into the 24v Kacher circuit.
   At this time I have 3 chokes on my device after the full bridge rectifier/capacitor. After having the same problems that you have mentioned concerning the Kacher's choke(s).  I'll look into this issue further, as my 10k pot, and 2k worth of resistors on the Kacher circuit are not enough to lower the current to reasonable levels. If the voltage at the kacher secondary becomes too high, the HV will arc to anything close to it, and start a fire if not stopped in time.
   Possibly a potentiometer at the Kacher's input may also help.
   Can you tell me about the wire gauge, number of turns needed, and which size and type of choke core are you using?
   Your reply is much appreciated,
                                                 thanks again,
        NickZ
   BTW:  Your Kacher circuit board, and yoke look very nice and well made.
NickZ
   AG:  Not sure what transmission coil you are asking about.
   The running frequency on my Kacher circuit is fixed by the turns ratios on the primary and secondary coil. No further adjustments are made to it, other than by moving ferrite pieces inside of the pvc former tube.
   My induction circuits are tuned for best outputs by the use of ferrite in the cores, and magnets placed on the yoke core.
The grenade output coil is 37.5m, and inductor is 18.75 meter long.
   At this time I'm not sure what the grenade running frequencies are at, as they are not what they used to be, something has changed, and that is what I'm working on now to discover, the current cause of why no "effect". Once I can get it back, I'll let you know at what frequency things are running at.
