0 Members and 524 Guests are viewing this topic.
conico
I used black toroid ferrite not isolated , 26mm diameter. The wire is 07-1mm in plastic isolated.
Don't use a toroid ferrite in colors, yellow, blue or green, thous are isolated and the inductance is low.
I wound 33 turns on toroid and i cut the wire at the middle at the 17th turn, in this way i have two coil  the same inductance.
first of all I wish you to try something.
I wish to disconnect the mazili circuit and disconnect the cap in series with 3 turns and  then connect the Katcher and see the power of it . In my case the power of Katcher was very low.
NickZ
   conico:
   As my Kacher circuit is connected to the 28t coil, through the full bridge rectifier, if I disconnect the 3t coil/capacitor yoke LC circuit, well, I don't know what will happen, but I'll let you know, in any case.
   What voltage is your Kacher circuit receiving now, with the Kacher's controller pot all the way down?
   What is you Kacher's input source connected to?
conico
 I use a power supply like Geofusion 24v , 10A for Kather and for push-pull to.
  With pot at minimum i have 23,3v and 0,27A for Kather.
If you use 50-60v for kather  you must have more turns on ferrite toroid , and inductance like 180-200 uH
i  wish  you to disconnect just the  the cap in series with 3 turns and see the power of Kather.
In my case without serial cap i have a spark of 1 mm on antenna and with 0,47uF cap connected is a 8 mm spark on antenna.
AlienGrey
Conaco, greetings.
Can I please ask the Katcher circuit Adrian uses on his device It looks as if it is free running, how does Adrian connect up and get his Katcher circuit gated as in the Stalker circuit it is different it is gated and uses an Mos-Fet.
As I am trying to sort some kind of PCB for my device.
Many thanks  Grey
conico
Adrian don't used a Kasher circuit ,he used a nanopulser , a driver and a mosfet. Stalker's diagrams page 1002
