0 Members and 282 Guests are viewing this topic.
Hoppy
Quote from: NickZ on November 06, 2016, 09:53:37 AM
   Hoppy:
You are always looking for how it does NOT work, and I'm looking at how it does work.
To be more precise and accurate, I'm looking at how and why its made to look like it DOES work as a self-runner.
and
to re-phrase your comment:  "It's not about who's "opinions" are right or not, it's about finding the true cause of self running devices."  I would contend that: It's not about who's "opinions" are right or not, it's about finding out whether these devices can truly self run.
apecore
Quote from: verpies on November 04, 2016, 02:14:52 PM
I haven't tried, but this guy seems to have tried it all and gave up.  What was wrong with his attempts?
Hi Verpies,
I reviewd all the Itsu video's and i think some short evaluation on the results would be usefull.
After all we all do have more experience at the moment.
In case of Itsu's experience:
Without discussing groundings or connection details, i must say Itsu did a nice job)
All the details are in the video's and the way it is build "excellent"
But unfortenatly no satisfied result.
One of the (main) problems/ issues was the placement of the nano puls on the sinuswave.
Why was it so small?
Can someone quantify how large (Vpp) this puls has to be?
And explain why in Itsu's case the puls aborbed?
Must we work with more HV (Higher voltage),...
Greetings
dxer_87
Many texts, not many understand my ideas.
1. Leave the grid on its place.
2. Connect to grid non-toxic sources.
3. Keep your organism protected while working.
4. Don't buy things after things. Functions are fine, stuff works, even if not at all - it's a man's creation.
5. Iron kills. Iron gives food.  - Iron gives opportunity to control the weather. But, do you need thousands of potential?
6. Ground more.
7. Use both hands and drill sometime.
beboszek
Quote from: itsu on November 05, 2016, 12:22:23 PM
Nice screenshots in that post, which are from your Grenade i understand.
Are they with the inductor installed?  And if so, what was connected to this inductor (open, 470nF cap or?)?
Yes, from Grenade. Its cold terminal connected to ground, hot to generator thru ~10k resistor. Spectrum taken directly on Grenade.
Inductor installed, with cold terminal grounded, hot left free. Both coils wound exactly as Siergiej is explaining in his video I mentioned.
Quote from: itsu on November 05, 2016, 12:22:23 PM[/size]
I think that your Spectrum Analizer and/or your FG are always connected to your house grounding, so the black leads of those instruments are always house grounded.
How would you measure the coil (grenade?) with the ground in the garden only, did you remove the instruments house ground?
I can completely separate instruments from mains and other grounds with battery powered inverter (only capacitive coupling ~50pF remains as battery is laying on the wooden table and thru the air).
Quote from: itsu on November 05, 2016, 12:22:23 PM[/font]
I used my DSA815 to characterize my Grenade in a similar way you did i guess (100KHz to 10MHz), see the screenshot below.
The inductor was open, when attaching a 470nF cap to the inductor, things change off course.
Regards Itsu
Because attaching a  cap to the inductor or shorting its leads, inductance of Granata itself changes much. I have the same findings.
Marek
T-1000
Hi guys,
Another weekend spent in the lab for me with some interesting things to discuss.
While I was working on the bench I also had a extensive conversion with akula and got some additional information to share
So here is base circuit for effects testing:
http://imgur.com/EYiSLsP
The spark gap B has to be adjusted in a way where it will be making spikes over flyback transformer to top load.
The spark gap in the top function is to short out charges and limit voltage. This is base fundamental condition for effect to happen in the coil which is driven by low frequency generator.
The whole circuit have to cause ionic winds which do not stop as soon there is discharge. Also nearby objects will also start emiting ion flows when effects are in place. So no power in circuit and ionic wind after is the target to collect in receiving coils.
This is based on what akula told me about key conditions to achieve.
I see Adrian (AG) is interested to see my bench so here it is... http://i.imgur.com/6XQeUxB.jpg
Cheers!
