0 Members and 139 Guests are viewing this topic.
AlienGrey
Quote from: conico on November 07, 2016, 12:39:31 PM
Geofusion can you tell what inductor do you have in your system? an 18,75 m or a 9-10 m wire long?
I hope you can tell something about how do you find  the resonance, just in words.
Hi Conico that snippet about the choke and 2 caps one each side wont the values need to be exact so the katcher switches on at the right place ?
NickZ
Quote from: verpies on November 04, 2016, 11:37:47 AM
Current flow does not have to be in the same direction as energy flow, so how can you be certain which way the energy is moving along the grounding wire?
  Using a car battery on a table as the virtual ground shows that there is NO energy coming from the ground. Or not?
Meta
If you want higher harmonics, use harmonic wire.
Platinum- 3rds, Magnetism
Silver- 6ths, Electric
Gold- 9ths, Gravity, Control
From John Worrell Keely
conico
Quote from: AlienGrey on November 07, 2016, 01:42:31 PM
I do not know, might
all I know is that Katcher has little power, no more than 1000V to the antenna but if the food inductor has the effect of amplifying 5-10 times for antenna, see Geofusion's last movie.
I reached at the resonance frequency and are only 2V the extra load like Itsu, in one of His movie.
Hi NickZ, a strange way to show is nothing on the ground wire.
https://www.youtube.com/watch?v=Dh4xTLEwI6w
beboszek
Quote from: NickZ on November 07, 2016, 09:25:43 PM
Capacitive coupling may be the issue here. That is 10^6 Hz frequency range.
