0 Members and 529 Guests are viewing this topic.
beboszek
Quote from: Utopia Now on November 09, 2016, 11:12:17 PM
Hallo Beboszek
Are you allready pulsing a Grenade Coil or  some other CW CCW coil  with your High Power NanoSecond Generator
http://overunity.com/downloads/sa/downfile/id/630/
Or have you modified it maybe.
I made some experiments with it in summer but now I switched back to tesla impulsed device. like Siergiey did. Btw, are there any ther meterials, documents concering his devices, other than those published some time ago in big *.rar archive on torrent?
Quote from: Utopia Now on November 09, 2016, 11:12:17 PM[/size]
But some questions :  the 0.4 mm Kynar wire is that the outer diameter ( Kynar  says something about the insulation maybe  ... ) or 0.4 mm copper with Kynar insulation.
Its the copper wire diameter, but its not critical. I made it with kynar because of good insulation (high voltages present). You can make it with ordinary magnet wire, but take double enameled one.
and what type of capacitors can you advice for C5 and C8   maybe from  http://www.tme.eu/gb/
And can i take3 times 2n2/10kV  instead of 2n2 and 4n7,  because 4n7/10kV was hard to find
C5 and C8 - bypass capacitors for mosfet driver, X7R ceramic cap will be OK. [/size]Place a 1μF or more bypass capacitor as close
to the driver as possible.
You can take 3 times 2n2/10kV - observe resonant waveforms for final tuning.[/size]
TME is a good supplier. I take most of my parts from them as I have them next days in home. All parts for this device you can find there, maybe except the core, which I bought in contrans.pl
at the input A3 there are 3 connections ... 1 is input i think, the lowest one is ground  .. but the middle one that goes via R8 to 12V  what is it for .
Middle is 12V power input.
Marek
GeoFusion
Hi Guyz
  Lost bro,
The schematics you have posted of Ibrahim are working ones.
But if you take a look at the TopRuslan with diodes  schematic you posted there,
see how the Kacher is build? see something different there right :),
That is one of the missing keys there which make things happen. It makes sure the field collapses
and max Ions are harvested. take a look. Ofcourse it can be done without it as I have shown but this is
Better method.
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg495329/#msg495329
that is correct ,
Ruslan is right, without those diodes it doesn't work.
I have even done the test my self, take a look, the Original Ruslan way, but did not continue on this path.
https://www.youtube.com/watch?v=1weV296sjHU&t=1s
Even Ruslan commented on this one ;D a good one.
Nickz, (all)
I think you might have past by the post with the latest on it.
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg495071/#msg495071
In attachments. here it is and with the next page there are the winding directions of coils. without meters givin.
Where you said,
"remove the ground, which causes the frequency to change, and a lowering of output, as well"
That is correct, and even connecting load strait to output grenade also changes it and has to be retuned
to get maximum brightness out, by only using freq tuner.
That is why yo have Auto resonance comparator on board Installed via their push-pull driver
and the use of Ferrite ring to sense. It all makes sense :).
The reason also why Ruslan also had small load first on his self runners is because if he places more bulbs or
load, the circuit dies, goes out of resonance, He should have adjusted the system everytime manually.. head ache.
There's but one thing I want to let know Nick,
You might have synchronisation but it is really not the same results exactly as what I have on bench
Until you have a TL494 / IR2110 driver for push-pull for the device at least. PWM & Freq have to be fine tuned.
But I really mean not just any TL494 driver for push-pull as many conventional build ones
have caps and other components which actually makes the power inverter efficient which in return
are not allowing certain actions to take place on the Ion device.
Akula's is one of them Which I know of are Legit Schematics, and some of Ruslan. Sergey also has some.
on the Yoke with the +-28T, follow the direction on how it's coiled and  to know which sided need to be connected.
If 28T is CW, follow CW motion onto the grenade and there you will know easily how to connect them
Same for inductor. follow the flow.
The board is designed in such a way which still surprises me..
It's best to let someone build it for you (all) or try to do homemade which will be time consuming if you do.
Lets see how it would work out when you apply the latest on your bench.
In that video which you haven't seen befor Nick,
Have you not seen the flashing LED light on the PSU-24Vdc?
It indicates me that the voltage is a bit to low on output. to keep it full alive and it gives that pulsation.
I'll have to see to increase the capacity of the unite to generate more volts,
that now is a puzzle for me.
Edit*: for coax cable one instead of kacher, same thing is focused on.
The collapsing field to attract Ions, Pulses. if not in resonance will not work.
The Sharp Knight if you will guyz.
and maybe Multiply them like a train ;) for more?
         Cheerz~
NickZ
  Geo:
  You mention: "I think you might have past by the post with the latest on it".
  I've seen it, and have even done the same using a laptop charger, as I only have one PS, which is used as my main input source for now.
  I don't use a "mediator coil", although I've built up several of them.  I don't need them, at all.  My system is not limited to just drawing 5 or 6 amps, either. I can do everything that you have shown up to now.  Even though I don't use a TL 494, or the Kacher interuptor transistor. Nor the comperator circuit, or any other circuit.
Neither does Roma on his super simple device, and is still getting 4000w output.
   If your voltage is too low to run the feed back path, see if you can at least get the push pull and Kacher circuits to run, with no load on it, first. But, from what I can see, the load is part of the circuit, and without it you won't get the system to allow to pull much "extra energy", Ions, Aether, or whatever, from the ambient.
  I now have my system connected as you have yours, and am seeing similar results. I don't need to see the "same exact results", but hopefully even better results.  As I don't have all the additional components limiting the flow, or flux.
   Have you connected the feed back path up, or not?  This is what we are all waiting to see.
   I'm doing my part, as well, to the degree that I can for now.
conico
Geofusion,
I see your last diagram and i think is your last setup, The Katcher is not connected directly to the ground , the inductor and the cap in series with 3 turns are not connected to the ground?
Did you used an oscilloscope and a function generator for finding resonance frequency?
Your last inductor is 18,75m in 3 layers?
Did you have a space about 3 turns between inductor and the rest of the grenade coil?
verpies
@Wesley
How is your Coleman FE coming?
