0 Members and 544 Guests are viewing this topic.
Hoppy
Quote from: NickZ on November 12, 2016, 09:27:47 AM
   Guys:
   Thanks for the info about the zener diodes. Sounds like they are big power hogs, so, the voltage regulators are the way to go then. I didn't know that about the zeners consuming the output and wasting it to ground.
Nick,
Its not just zeners that rob energy being transferred from input to output. Any component in the device that gets above ambient temperature is wasting energy, if that heat is not required for a practical purpose. Any looping back from output to input would first need to make-up for these energy losses before it had any chance of self-running and this would clearly not be possible unless the process of looping-back in some way initiates the 'capture' of external energy from some source external to the device or through the transmutation of a material in the make-up of the device, as Wesley is working on with the Coleman device.
NickZ
  And just how would you know if there is any material or nuclear decay or not going on? Especially while the HV will make any geiger counter sound off.
  If NMR were the case, I would stop working on these devices. But I don't believe that that is the cause of any of the extra energy responsible for THESE types of devices self running. Time will tell...  But, that is what we will need to test, somehow, once we get something self running.
   As far as I've seen, or can remember, there are no zeners on the Ruslan device, at least not on my device, other than 6v ones on the fets, and what may be inside of the PS. So, there shouldn't be much waste from the zeners there?
   And does this also means that such as on Geo's device, any power output not being used, passed his 5 amp draw from his 15amp PS, is being wasted? Or not?
   Overheating of some of the components, yoke coils, and grenade output coil, and Kacher circuit, is still a problem, after running the device for a while. There is already lots of waste being lost as heat.  So, controlling this possible overheating issue may be an important consideration.
   I believe that on Sergey's device diagram he does not use a commercial "el cheapo" PS for the feed back loop.
   He also adds more turns to his yoke secondary, as does Adrian. Which may be the way to go to obtain higher output voltages, than just 60v.
   Hoppy: You mentioned, "Its not just zeners that rob energy being transferred from input to output."
   That is one of the reasons why I want to use the least possible component possible.
Hoppy
Quote from: NickZ on November 12, 2016, 12:41:06 PM
  If NMR were the case, I would stop working on these devices. But I don't believe that that is the cause of any of the extra energy responsible for THESE types of devices self running. Time will tell... and is what we will need to test, once we get something self running.
   As far as I've seen, or can remember, there are no zeners on the Ruslan device, at least not on my device, other than what may be inside of the PS.
   Overheating of some of the components, yoke coils, and grenade output coil, and Kacher circuit, is still a problem, after running the device for a while. There is already lots of waste being lost as heat.  So, controlling this possible overheating issue may be an important consideration.  Or not?
   Sergey's device diagram does not use a commercial "el cheapo" PS.  He also adds more turns to his yoke secondary, as does Adrian. Which may be the way to go to obtain higher output voltages, than just 60v.
NMR detection is best answered by Wesley.
Its not just zeners, ordinary diodes can get hot.
Increased secondary turns on the yoke will increase open circuit output voltage but this may not translate into brighter bulbs because of voltage drop due to the loading on the secondary winding. You may find that by adjusting the duty cycle with a PWM push-pull (or even with your mazilli), together with a pulsed cap discharge output, that the bulb(s) will appear visually brighter to the eye with no alteration to the yoke secondary winding. You will have seen some examples of claimed self-runners using pulsed outputs.
GeoFusion
Hi guyz,
  all,
Well, I am not here for fame, I am here for research and sharing what I have and what I can.
many thing still have to be solved, I am learning as we all do everyday.
there is absolutely no room for competition...But work together as a Humanity.
Nick,
It's alright, no harm.
The main thing on these devices is the Ionic Wind, The radiant energy which be harvested within the grenade and inductor and synchronizes and yet goes in resonance with it. :) The Electrostatic which is activated will be drawn and goes in phase with the amps
are created on the coils.
All,
Akula and even Ruslan mention BEMF on their talk and diagrams. this what I know.
very important.
So to say is we search for resonance on the coils but it's not only that..
It's to find that spot and Peak where the Ions come in greatly for harvestation!
Edit* This is that external energy most of the ppl are asking for and what it is.
Just to make things a bit different,
there is another resonance spot or harmonic on my device where the freq is higher where my amps go up
till about 7 amps. Of course I have not shown that on recordings but, that is one different one and not so Efficient spot.
Conico,
Nice work on the bench, I am happy to see those results :).
saw the video.
about the setup on my bench on what you asked.
The kacher's ground I could disconnect and will have the results you have seen on recording with no problem
but it will do better if it's connected to the ground connection of the circuit.
But with or without to get good output needs to fine tune it to get it on right possistion  of waves.
Inductor and the cap in series with 3 turns are also one side connected to ground and first layer Grenade
in video it's the red wire, can't miss it.
It needs to be connected in this way with this setup to get effect in great condition.
Yes, I do use the scope which is a software on my pc but it's for me to see the wave forms for the moment
and the frequencies but when tuning It's hectic as it can ( almost everytime freeze it) but we can see movement.
My inductor now is 20M
Grenade is 40M
to be exact it is 20.4M with what is not coiled connected to the yoke and caps.
which makes grenade 40.8M.
Edit* 50MMsquar plastic tube
That is it :).
Let's continue on this journey
   Cheerz~
Hoppy
Quote from: GeoFusion on November 12, 2016, 02:36:24 PM
   Cheerz~
I rather like that description of the 'effect' Geo.  :) It sounds quite heavenly.
