0 Members and 334 Guests are viewing this topic.
br549
I am starting to do some bench work again, now that summer is over and was wondering if you guys could answer a couple of question about the below circuit.   and thank you ahead of time.
AlienGrey
Quote from: br549 on November 15, 2016, 04:39:26 PM
try page 1049.
conico
 br549,
You will tune your device later and at some frequency and some duty cycle you will see 7-8 Amps from your PSU. You need chokes who will resist at 8 Amps. I don't think you can find to shop them.
At page 1049 , I posted but NickZ told me something is wrong with my Katcher , he was right, it has no power . I found the problem, my choke from katcher has two terminals vice-versa, I change them and a big power was for Katcher, around 6 A from PSU for it.
So,
Good luck!
NickZ
  br549:
  Geo used a green color coded ferrite toroid core for the "mediator".  It's about 1 1/4 inch wide. You may be able to find some of those in some power supplies circuits, which can be removed and rewound, or you can use a 2 1/2 inch tv yoke core, instead.
   The smaller choke on the Kacher can be found on the input to the old crt monitors or tv sets, or old Pc power supplies, which can be used for the Kacher circuit. But, I find that they will get hot when powered from a 24v and 10amp power supply, and may need an additional choke before the induction circuit, also.
  I found that the small green mediator choke with only 12 turns can still allow too much current into the induction circuit. Therefore keep that in mind, and watch the overheating of your fets, or yoke coil.
  I use two one inch size yellow iron powder chokes before my induction circuit, to keep the heat down, but I don't use the mediator coil. Although I may try it, again, sometime. Geo mentioned that a tv yoke core can be used as a mediator also.
  You will need to test all this on your own system.
   Here's a pic of what my "mediator" choke looked like. But like I mentioned, I'm not using it anymore. You may find that you need some additional chokes also, to keep the heat down on the induction circuit.
   conico:  That's good that you got your Kacher running with more power now. You should be able to observe up to a 1/2 inch streamer, coming off of the antenna coil end, if all is working properly. Remember to connect an earth ground line to the Kacher's emitter, which also connects to the grenade output coil, as well as to the 3 turns coil's 0.47uf capacitor.  All three earth ground connections to both circuits work together.
Hoppy
Nick,
Please resize your image above!
