0 Members and 360 Guests are viewing this topic.
NickZ
  Just as a comparison, here are both my gate, and drain signals.
  Kacher is also on, and 3 100w 110v bulbs partially lit.
  Let me know what you think. I see NO spikes. Well, maybe just a little distortion of the wave form at the top of the gate signal.
verpies
Quote from: NickZ on November 20, 2016, 06:03:46 PM
Your gate waveform has atypical shape but it appears clean at this zoom level.
NickZ
   Verpies:
   OK, thanks.  No spikes on the push pull being affected by the kacher's pulses.
Ground lines are connected, two ground lines, one for the kacher, another for the induction circuits..37.5 meters each line.
   Closer inspection shows the high voltage riding inside of the push pull's wave form, at the output wave forms, as seen on the scope, at the bulbs.
If I get any closer my camera will not take the picture, so that is as close as I can get without problems from the HV interference. Same with taking videos.
  HV lights CFL bulbs Up to 15 inches away from the antenna coil. 1/2 inch streamers. No ferrite inside of the kacher secondary coil. No ferrite inside of the grenade coil former tube. Magnetite inside of the yoke core.
magpwr
hi everyone,
I have just uploaded my latest prototype circuit into youtube-
High efficiency tesla driver circuit with interrupter 2.0
https://www.youtube.com/watch?v=NU2rMlRpCNA
Resonance frequency of test tesla coil is less than 2Mhz at around 110turns with Akula design with few turns of high Q coil at the top portion.
Using mere 12.8volts i have achieved internet highest "88volts" per turn at the tesla secondary coil using around 1.6Amps only.
The hv mica capacitor connected  in parallel with 3 turns primary helps improve output voltage.
Technically the kacher/tesla coil is also considered "high voltage nanosecond generator with interrupter" operating at nearly 1.9Mhz for the test tesla coil.
For curiousity this above circuit do generates 1.7kvpp using only 3volts from supply since i am only using cheap XL6009 buck/boost circuit from ebay to generate 20volts for the mosfet driver IXDI614
apecore
Nick,
It seems to me that your signal is not being affected by HF/HV interferences.
Wouls this ends the discussion as Hoppy stated that the effect is created by additional gate pollution?
Kacher does do its work as it should.
Unfortenatly Nick....no Input/Output power indication.
I am very excited what Hoppy's comments will be ;)
