0 Members and 274 Guests are viewing this topic.
lost_bro
Quote from: magpwr on November 21, 2016, 03:20:40 AM
hi everyone,
I have just uploaded my latest prototype circuit into youtube-
High efficiency tesla driver circuit with interrupter 2.0
https://www.youtube.com/watch?v=NU2rMlRpCNA
Resonance frequency of test tesla coil is less than 2Mhz at around 110turns with Akula design with few turns of high Q coil at the top portion.
Using mere 12.8volts i have achieved internet highest "88volts" per turn at the tesla secondary coil using around 1.6Amps only.
The hv mica capacitor connected  in parallel with 3 turns primary helps improve output voltage.
Technically the kacher/tesla coil is also considered "high voltage nanosecond generator with interrupter" operating at nearly 1.9Mhz for the test tesla coil.
For curiousity this above circuit do generates 1.7kvpp using only 3volts from supply since i am only using cheap XL6009 buck/boost circuit from ebay to generate 20volts for the mosfet driver IXDI614
Good day MagPwr
Nice work, thanks for sharing;
I cannot read your attached diagram..... it is low resolution, can you please attach another with higher res.
Thanks in advance.
take care, peace
lost_bro
EDIT; just took screenshot of diagram from you YouTube channel, thanks
NickZ
   apecore:
   True, no input to output readings. Nor do I need them to show me what I already know. That there is no OU.  Nor does anyone else have it, either, yet there are self running devices. With more of them coming out continually.
   OU will only manifest it's illusive head when you can pull in extra energy from the ambient. But, at which point IT won't be OU either, as that does not exist, and never has existed. EVER!
   These are surrounding ambient Aether conversion (Ions,) devices. Not OU devices. As any extra energy has to come from somewhere, and not from "more out than in" false logic,  which is just plain dumb, especially hearing that from the forum members in this thread.
   Wesley states that it's ok, if you don't PAY for the "extra energy".  Such as with NMR, but, That is not the point, nor is free, as it's burning up matter to do so. Like burning wood or coal, is not OU. Even if it's free to pick up on the ground. It creates pollution, in one form or another.
  Lost-bro:  Can you please upload Mags higher resolution image from his video that you have.
bitbo
Here the bigger screenshot from YouTube:
verpies
Quote from: NickZ on November 21, 2016, 10:20:03 AM
Converting coal to energy yields 35MJ/kg, wood - 18MJ/kg
...but completely converting matter to energy non-chemically yields 90000000000MJ/kg.  That's essentially free.
What pollution ?
NickZ
  Are you saying, now, that the process of NMR emits no radiation?
No isotopes such as from hydrogen, giving off Alfa, Beta, or any other negative emissions.
  Wesley can possibly chime in on that one.
   Non chemical, as in what conversion process?
   In any case, I chose to go with exploiting and tapping the available ambient energy, instead of converting matter to energy.
   NMR is another subject.
